View Full Version : Engine & Drivetrain
  1. Anyone think the Z's clutch is a little noisy
  2. Transmission Removal/Jack Question
  3. ENEOS 0w50 Nissan 350Z Test
  4. The "transmission Issue"
  5. sticking clutch
  6. Anyone ever changed spark plugs???
  7. AN fittings question
  8. Front main seal
  9. which pulley do you guys think is better?
  10. Clutch Slipping Issue
  11. some ideas
  12. Nismo Clutch: Japanese? or US? Is there a difference?
  13. When To Change Plugs
  14. Installed Clutch......Having problems
  15. low H/P gains from utec
  16. How much power?
  17. Trany and drive shaft
  18. OEM ECU, Data Log?
  19. Better sound from intake
  20. Variant of the "Clutch pedal springs back up halfway" problem
  21. Master Cylinder Is Growing Algae
  22. Third gear going?
  23. installed spark plugs..
  24. Feeler: Possible SR20DET Rebuild
  25. Differential drivetrain problem..HELPPPP
  26. $2500 budget
  27. couple codes...still confused
  28. I just got my new motor
  29. I need an experiance VQ engine builder to tell me what this is.
  30. Agency Power or Unorthodox
  31. Intermittent shaking
  32. JWT Flywheel and Clutch/Pressure Plate
  33. Voltage Issue????
  34. AC pulls the RPM of the engine up?
  35. Is this normal?
  36. Camshaft cap order for the 03 VQ does anyone have it?
  37. Compact Car Magazine competes in Castrol Top Shop Challenge w/ a 350Z
  38. Question about some clutches.. help
  39. Short Shifter - B&M (Yay..or..Nay?)
  40. Rear diff
  41. problem with ACT flywheel
  42. Easyiest Way to pull motor
  43. NA Cams==> woth it ???
  44. 06 350Z engine question
  45. clutch problems at the track?
  46. Weird hissing noise under car
  47. Idle Air Volume Learning - The car does not remember after a restart!
  48. Engine Valve Chatter
  49. So...Cams, Valvesprings, retainers, P&P, 5/16ths iso thermal blah blah - what to do?
  50. Tranny recall attempt
  51. I've decided to switch over to Mobil 1 Extended Performance
  52. Valve body and torque converter upgrade for 5AT, some solid feedback please...
  53. Greddy 15mm Oil Catch Can Install
  54. Bunch of upgrades.....
  55. HELP!!! I can switch gears without pressing the clutch!!!
  56. Rev up and Non Rev up Valve Covers the same?
  57. Vh45dett ?
  58. So I have to pull my engine so Ill be starting a build
  59. So I got closer to my problem update
  60. Rattling sound....
  61. Is this true? VDC, TCS question
  62. Clutch problem need help asap!!
  63. My HOT Z?
  64. 5at
  65. Engine Problems update !!!
  66. MAFs, Throttle Body & Ignition coils same as other VQ35 cars?
  67. Sierra Coolant, safe for pets, children, and out MOTOR?
  68. Anyone experimented with HHO supplement / Water fuel in their Z?
  69. quick question
  70. Water Temp Adapter Question
  71. Sard Power Band
  72. 3.357 Final Drive Gears
  73. RPMS not consisten while punching it
  74. differential problem?
  75. Competition Clutch Issues!
  76. How do i get to the fuel rails to test pressure
  77. Fuel Pressure Question
  78. 02 Sensor Wideband or Narrow Band?
  79. Nissan Coolant, is it real dark in color?
  80. Engine problems just tonight HELP!!!!!
  81. idle and 8 bar oil pressure
  82. what spark plugs
  83. Water/Methanol Injection Recomendations
  84. oil change
  85. is JWT clutch same as stock?
  86. blown clutch
  87. Clutch engagement after SS line install?
  88. Need help w/ AVID Racing Tranny Mount!!
  89. Air conditioning help pls?
  90. COLDER COLDER got to get COLDER!!!
  91. new bearings with LSD install??
  92. jwt flywheel and clutch install problems.
  93. Stock clutch question
  94. Fluids
  95. Good Clutch and Fly wheel?
  96. top speed pro 1 engine dampner installation help
  97. VIDEO of my clutch squeak...anyone else?
  98. Took Z in for 5th gear grind but tranny repaired instead of replaced?
  99. 7,000 Miles> transmission FAILED
  100. whistling/squeaking noise while accelerating?
