- Recall question
- JWT clutch and ACT flywheel
- Good Motor Mounts?
- MOCAL Sandwich adapter - proper fittings question
- 350+ hp on stock block?
- Another oil-related thread...
- Can someone explain what these are in the engine? PICS
- M/T tranny oil
- Need reviews on Short Shifter.
- Oil pressure?issue?
- Anyone tried E3 Spark Plugs w/Diamond Fire
- NA Build in Mid 300s?
- Oil pressure drop
- Need cats for g35 coupe
- how the rev matching feature of the 2007 5AT works?
- injector install cost
- Who thinks the engine bay is too tight
- what the F**K ... I was stranded
- circuit sports short shifter
- Noisy a** flywheel!!!!!
- HKS DLI II twin power install prolblem
- Oil in the Spark Plugs?
- Automobile magazine reports poor clutch operation
- Help!!! Oil Pressure!
- Car wen't dead! help please!!!
- 5th Gear Grind
- Help identify undercarriage component?
- How to tell if clutch is bad?
- Exedy Flywheel Failure!
- quick question
- running rich on bank 1
- Lightweight flywheel question?
- My review of the 4.083 Final Drive Gears
- Need help on my Z making auto feel like a manual
- I was wondering why tranny shifted kinda rough **PICS**
- Non Rev up, Rev up, Hr???
- Clutch + flywheel combo?
- Need More Help with SWAP!!
- So are the 300 hp motors just junk
- First Oil Change questions (yes I'm a noob)
- SprintBooster Review
- Getting a New Z, LSD ?'s
- Clutch Master Stage 2 and Light Weight Flywheel
- Another lsd question
- Exedy Flywheel Reluctor Failure
- Attaching Gas feed for vortech
- 350z 900hp Drive shaft shop axles - Torque setting
- ECU Reprogram
- OSGiken TR2CD Twin Plate Clutch & Superlock LSD *Picts!*
- Got my new Z. Rocks in TIN can NOISE in neutral.... ??? Help
- white smoke under the car
- Using 89 Octane on 2006 350Z?
- 2004.5 Oil Consumption?
- do you use 5W or 10W30?
- GReddy E ultmate ignitons problems
- JWT Clutch/Flywheel Review
- I couldn't help it
- Pulleys ???
- Clutch Master Cylinder Question
- Cheapest place to by 3.9 Gears?
- what the?
- Best way to get more power from my engine!!
- Screwed by dealer
- 270whp VQ dyno!
- The reason for this sticker
- Breaking-In a Brand New 2008 350z? How?
- help my ignition coil keeps blowing!
- Pulstarplugs....any good?
- Dyno Results
- Very weird incident with my Z??
- Another 4.08 GEAR review
- What year VQ?
- Where to find MOLYKOTE M77 Grease
- Finally Dyno'd
- Automatic 5AT tranny shut down?
- Weird losses in power
- New Transmission
- Help My Check Engine Light Keeps Flashing!
- Stock N/A getting too hot on hillclimbs
- How hard is it to actually blow a stock VQ motor?
- my 5th and 6th gears grind
- motor pics and dimensions?
- Strange grinding sound
- Clutch pedal not returning to normal rest position
- Flywheel question
- Oil Filter Stuck - Advice Needed
- ACT FW and Nismo C/K
- Is it good together.
- Clutch doesnt stick to the floor, but doesnt come up all the way.
- Universal Dyno Law
- Transmission hum
- Lightweight FW Chatter Fix? Idle + 3.9 Final Drive?
- Cylinder #6 dead?? please help
- Clutch kit and flywheel
- Oil for MT?
- Solid Motor Mounts
- Head Gasket/CAMS???
- what can be causing this??? pics of plugs---
- Oil Pan Bung - Oil Temp Sensor Mount
- LSD vs. Traction Control
