- Long term odyssey pc680 battery review.
- Clutch Burn & Slip at Hard Takeoff
- 420z
- Unorthodox Racing Pully Belt Question
- Intake Supercharger
- Opinion on Engine Performance
- Looking for suggestions / advice
- Problem with car starting
- what lsd and gears for boost?
- Clutch/Spark Plug issues?
- DIY thermostat delete
- transmission rebuild vs replace
- Knock Sensor Sub-Harness
- clutch and flywheel
- Dyno Results for a 2008 z33 w/ full boltons
- Dyno is a heartbreaker
- Problem : Nismo GT PRO LSD
- Activities of the Oil in Various RPM Ranges
- Upgraded to the 1.09 Haltech software, MAF setting
- 350z Oil pressure sending unit
- My SIKKY LS2 install thread
- Timing retard for pinging
- Does my car have a chip/reflash??
- Transmission swap
- differntial ID
- slipping clutch?
- What flywheel is this?
- Possible trans swap steal.
- Would this part come off during clutch replacement?
- Help.. LSD parts question
- engine swap
- gas mileage drop
- engine swap
- Z Build Well ON ITS WAY! Almost Done. LONG POST
- Plenum spacer question.
- growling from engine
- Strut Bar for Kinetix V+ w/ 05' hood
- 2nd gear
- Clutch and Short shifter
- MPG/Oil psi/ Spacer question
- Bleeder valve question.
- HELP! Having Problems..
- Questions about VQ motors
- Cam install help
- Auto dipstick level *PIC INSIDE*
- Clutch plate damage
- what wires are these? PICS!!
- Oil cooler mounting...
- 5/6 Fork Busted
- Mizu radiator, fans and hoses installed (with Pics)
- Clutch problem!
- clutch/flywheel
- Fuel Pressure Regulator Help
- Is it possible to ride clutch in neutral?
- OEM clutch or after market clutch?
- Difference between Nismo 380RS and normal HR
- CEL p1148
- Tranny Power Adders???
- Who makes JWT clutch & flywheel?
- southbend clutch
- what tranny do i have?
- cold start up makes sputtery sound
- 6MT Hard Going into 2nd Gear
- Best bolt ons for a 350z?
- Clutch Flywheel combo
- New Lightweight Flywheel, hard to drive?
- How is the manual trans?
- Random thoughts... 5AT to 6MT trans swap?
- Air/ fuel ratio wire color?
- Brisk spark plugs.
- New clutch = new rear main seal?
- LS1 STS questions
- Revup shortblock questions
- No more hair to pull out, Throttle response!!
- make Clutch ss line help
- Final Drive Install Price
- Best Oil Brand/Grade for Revup that eats up oil?
- Clutch Master Cylinder being moody?
- 03 transmission post #30457
- The Official LS Swap Info/Questions Thread
- weld-in oil drain bung
- Oil pump lifespan? Worries on High-Milage VQ?
- Clutch and flywheel
- Oil light + low oil pressure
- new clutch and flywheel
- Oil in plug tubes, 3-5k "clatter"... related?
- Weak Spots In Powerband..
- vq35 top end build
- Anyone With Transmission Coolers?!
- JWT Clutch flywheel combo in trouble after only 2 yrs?
- nna not following their warranty?
- Denso iridium spark plugs
- Changing from Auto to Manual transmission, worth it?
- VQ35DE Flywheels and Rotational Mass Discussion
- 07 350z clutch bleeder valve location.
- 3.7 FD gears and Nismo LSD in 5AT car
- 07 350z clutch stuck need help to bleed!
- Fuel Pump Question...
- Cruise control for base 2004 Z
- LSD for 5AT?
