View Full Version : Engine & Drivetrain
  1. Good or bad idea to install flywheel, with oem clutch?
  2. hydra ems
  3. Rattling Noise 06 350Z
  4. Questions regarding a mod I'd like to do (4.08:1)
  5. Is Amsoil XLF much worse than Amsoil ASL?
  6. High idle after cold start on 2007 model
  7. 94 Octane... pinging ??
  8. Will Clutchmaster FX300 w/ ACT Flywheel be a good/safe combination??
  9. Oil filter relocation
  10. Anyone know HP & Torque #'s on Stroked Blocks?
  11. cancel, cancel
  12. 6mt was stuck in gear!
  13. Engine Service Soon Light came on...
  14. Where to get German made Castro Syntec 5-30W
  15. Manual Shift Option On Automatic
  16. Something is up with my rear end
  17. Schaeffer oil, Where Do I Buy?
  18. Oil leak...
  19. auto to stick tranny swap?
  20. How many quarts?
  21. I'm overheating BAD!!!
  22. MY2007 313PS 350Z: which Clutch/Flywheel kit ??
  23. Valve body impressions?
  24. ECU compatability
  25. Tac freezing
  26. Oil Catch Tank Confusion *searched and researched*
  27. And the other guage
  28. Hooking up vacuum gauge
  29. belt question, need answer asap
  30. Engine oil for Z..
  31. P 2135 CODE (04 350z)
  32. Gear and LSD oil ??
  33. Clutch Question
  34. Place to purchase whole rear end with gear?
  35. where is the ecu scanner plug in located d on the 350z.
  36. ACT Vs Stock Clutch & Flywheel
  37. Clutch Question?
  38. ACT Clutch and streetlite flywheel
  39. Spark Plugs with Oil Consumption Issues (see pics)
  40. Altered Atmosphere
  41. 350Z Fluid Capacities Chart
  42. Today My Throttle Stuck... Help!
  43. Changed upper radiator hose now car running hot...?
  44. CVT trans?
  45. Clutch wear
  46. dyno upset
  47. weird popping noise
  48. Why no start when hot?
  49. ??? white smoke and lots of water vapor coming out exhaust????
  50. SES light
  51. Installed JWT Combo and more but something wrong...lots of questions Help!
  52. injector o rings and gloves. whats the deal?
  53. NA Build Q's
  54. Narrowband AF gauge..Which o2 sensor??
  55. OK to reuse intake manifold gasket?
  56. carbon fiber driveshaft?
  57. Radiator caps question.....
  58. When is too early for a flywheel?
  59. Will a rebuild cure Oil-Consumption?
  60. clutch/flywheel question
  61. Clutch Delay Valve
  62. Faint Smell Under Car
  63. Supercharger
  64. what else causes limp mode :(
  65. Rb26?
  66. Signs that your VLSD is going (FIX SEARCH BUTTON)
  67. Odd shake/grind in the shifter
  68. 03 base 5th gear grinds
  69. Nismo Oil Cap
  70. Engine knock: after H.T.M plz help
  71. No LSD oddity
  72. Will not start
  73. Engine Serial Number?
  74. Auto Tranny Shift Shift Problem
  75. N/A build
  76. Coolant System Problem
  77. 04 Tranny
  78. First Engine Mods....Help Please
  79. Monitoring oil press/temp - small LCD type screen
  80. Silly Question
  81. Cosworth Heads
  82. LSD question?
  83. Friction Modifier for rear dif?
  84. Anyone Using a ScanGuageII in their Z?
  85. exedy vs act flywheel
  86. wastegate/pulseplugs/EMS
  87. does anyone know how to change a clutch in a 350?
  88. Exedy clutch and flywheel reviews
  89. Coolant Freez
  90. 07 engine to be replaced, will it be as reliable?
  91. Fuel Pressure
  92. Sharif can do it backwards too!
  93. Clutch problem
  94. Tranny issue on 5AT
  95. Happy with my Mishimoto radiator
  96. Problem with my Z upon ignition
  97. is this a bust
  98. They say "Throw out Bearring" I say "I dont think so"
  99. Before/After Header Guess
  100. Engine mount that will fit APS TT kit
