View Full Version : Engine & Drivetrain
  1. horsepower
  2. Bellhousing bolts.
  3. Changed M/T Fluid now PROBLEM!!!
  4. Dealer put GL-5 in my 6-speed!
  5. New Tranny
  6. Transmission / shifting
  7. Check pics - Which engine VQ35DE or VQ35HR ?
  8. Clutch Pedal Click?
  9. Parts from Iraq
  10. Pics, Painted My Valve Covers, Polished The Timing Cover And Hide The Wire Harness
  11. Stock rear differential cover thickness?
  12. Act street clutch and prolite flywheel installed
  13. Alright.. General Question
  14. Car is hitting fake rev limiter at 2500
  15. A/C problems after TT install
  16. Installed 3.9 FD and worse acceleration
  17. Grinding start
  18. Z1 Motorsports Clutch/Flywheel Kits
  19. 04 350z CLUTCH
  20. JWT Twin Turbo 530 Kits
  21. What's the real benefit of silicone hoses?
  22. Stripped Stud during spacer install--advice needed
  23. DIY Radiator removal?
  24. Stock Gearing question
  25. where does this connector go?
  26. clicking?
  27. Changing Oil: Crush Washer?
  28. Buddy Club Shifter
  29. Any ACT Clutch owners with the 350/evo Rogue Shifter??
  30. Don't have time to search, need help now
  31. Just picked up the MAC Tools Crecorder ET3010
  32. Fluctuating Idle with tendency to stall???(video)
  33. Intercooler spray kit? Does it work?
  34. My Dyno Results.. Unsatisfied. (Graph)
  35. Valve body upgrade (Reprogramming kit)
  36. Any way to do this tranny swap?
  37. does the 07 come with 2-way diff?
  38. changing the oil question..
  39. Oil?? how much??
  40. Short shifter and tranny issue ?
  41. What is this device???? I can't figure it out..
  42. engine shipping
  43. torque specs for valve cover
  44. 2 Way Differential
  45. PRM kit - dyno results
  46. Lucas Synthetic Oil Stabilizer
  47. Clutch Sticking
  48. What are some consequences of running too lean?
  49. Knocking sound when backing up
  50. How Long Does It Take to Reset Readiness Codes
  51. Injectors anyone.....
  52. 03 Tranny
  53. Need Jwt Clutch/Flywheel Help
  54. Welded Diff
  55. help! twin turbo Z lost power
  56. ARC Oil Cooler install problem
  57. what should I do
  58. Royal Purple 5-30 or 10-40?
  59. damn revups...
  60. Weird issue with SGP built 5AT...Have some questions
  61. Oil cooler prevent oil burn?
  62. Slip and VDC lights came on
  63. Goodbye OEM internals.
  64. clutch "pop" noise when releasing the clutch slowly...
  65. My NA Build -Projected
  66. Valve Ticking??...HELP!!
  67. For those using or thinking about using Amsoil!!
  68. Ac line disconnect how?
  69. Flywheels and Clutchs
  70. Cosworth Builds N/A 400Bhp VQ
  71. good so far?
  72. HR head gaskets and bolts on a DE
  73. nismo diff clutch pack adjustment
  74. 3.7 final in a Auto diff.?
  75. engine higher on driver side...!!!
  76. xtd or f1 clutch and flywheel combo
  77. aluminum & chromoly flywheels?
  78. HUGE oil problem- 120psi.
  79. Slight hesitation about 4K RPM after Amsoil NanoFiber drop in?
  80. What should i do next?
  81. pulstar plugs dyno run RESULTS..
  82. SR20 in a 350z?
  83. 100 octane tune NA
  84. Quick question: starting in 2nd bad?
  85. White residue on bumper after spacer install?
  86. Attesa-ets
  87. Need some opinions...
  88. Low compression Piston 8:5
  89. can you get 200 rwKW on a Z N/A ?
  90. ATF J matic fluid
  91. oil leak valve cover help!
  92. new engine mods
  93. slipped out of 2nd - What the?!
  94. 06 Oil consumption a problem with AT?
  95. Air Ducts?
  96. Start up problems#2
  97. Would changing cams affect the AFR?
  98. Start up problems?
  99. whats the highest octane???
  100. bouncing off rev limiter question
