- transmission problem
- Greddy Oil Catch Can help
- check engine light on after test pipes
- valve train?
- Transmission not shifting, please help
- Should there be a Normally Aspirated Sub Forum?
- 10lb Clutchmaster Flywheel w/ ACT Street Clutch?
- No one will install 4.083 gears!
- NA Stroker? 100mm Bore? Both??
- Clutch issue- hydrolic components...
- Lsd
- Advice - Blown Motor / Stillen Supercharger
- Installed Nismo diff and Transmission question
- RC 440cc injectors fit 350z and G35?
- pinion help
- Battery Drain Since FI?
- nismo finned diff. cover?
- ZRidder19 told me to...
- Suppose some idoit left their oil cap off for 250 miles...
- How much costs a new cylinder head from Nissan?
- auto tranny owners
- 04 vs 06 6 speed trans?
- What's the part responsible for clutch chatter?
- Okada Project Direct Coil - VQ35DE
- Oil Level Mistery
- Rough Idle (Video)
- How much horsepower over stock can the Z's Auto tranny handle?
- Forged Tuned stock motor w/ bolt ons & cams results!
- JWT Popcharger Cleaning
- Launch Control for 5AT auto transmission?
- reasonator Question????
- Water Temp!!
- Recommend weight for differential
- lifts used for engine swaps
- What does code P1273 mean?
- Aftermarket Throttle bodys?
- ive got a question
- Scared of Repair costs!!! Help
- Redline 75W90 or 75W90 NS
- Advice needed for valve cover swap
- Differential?
- vq35 vs vq35HR
- Dyno Graphs
- can i drive my 350 without the strut bar?
- Non-rev ups redlining at 7000+RPM, talk to me.
- Motordyne Deals
- Slight Right Turns KILLING me!!!
- 350Z Fuel Level Sending Unit???
- replacing the ECM??
- CEL Fix
- Next mod after intake & exhaust, headers? whats recomminded?
- Clutch Engagement Point: Adjustable?
- Replacing clutch what parts are necessary?
- Cusco LSD Promotional Video
- opinion where to sell manifold?
- first mod question?
- Underdrive pulley belt sizes?
- ACT Prolite Flywheel
- Carbonetic LSD
- where to get FD gears installed?
- Flex-a-lite Low Profile Electric Fans?
- so you're a drop of oil...
- AC problems?
- Gauge sensor mounting question . . . .
- rc 440 install question
- throttlebody noise?
- RPM's up and down at idle
- 350z factory clutch?
- Latest dealer scam: Engine Oil Flush
- Launching the Z
- EXTRA Horsepower
- which one: new gears or twin turbo?
- New supercharger!!! HAH I thought i saw it all
- VLSD vs. LSD... same thing?
- Are all RTV's equal??
- Oil Pan Upgrade Question
- Main Bearing Marking...
- Sticking throttle body?
- 2006 owners
- Gasoline Brands
- What is the best way to flush out Power Steering Fluid???
- 06 V2 motor dyno #'s?
- Would You Ugrade MotorMounts on New Mot
- Tell me you've seen this
- Showing Off My New Project
- Any SPEC super twin clutch experience?
- WTF is wrong with my O2 sensors
- Cruise Control Problems related to Clutch
- synthetic vs non-synthetic oil?
- Vortech Installer In Nw Indiana
- Engine Hesitation
- Dyno 06 Revup with Bolt on's.
- where did you go to...
- Couple question about swaping in a 6MT
- Throttle body or map sensor?
- About VDC on 04 350Z Base
- Oil pressure gauge readings
- Need A Clutch For TT Setup
- Grounding the engine G35 vs 350z???
- -----> 2007 ENGINE on e-Bay
