- Clutch / Starting Car
- Where to buy Auto Transmission Solenoids?
- Nismo GT Pro LSD 38420 RSZ15-4U....need help
- pulse plug install...
- Labonte Meth Injection 3D Controller....???
- Valve adjustments?
- Is this rattle normal for a VQ? *Video
- Clunking from rear
- anyone know about this type of transmission on this 350Z??
- Valve Covers...symptoms
- 6spd man non turbo mods!!!!
- ACL bearings=Cosworth bearings? Best bearings?
- Plenum Spacers?!?!?!
- Underdrive Pulley
- Squeaking Clutch Pedal
- oil consumption
- car wont go pass 3k
- Cusco RS – opened up (lots of pics!!)
- differences between FWD Vq35de and Rwd Vq35de
- Some Upgrades Coming my way
- Best Performance Mods for N/A 5AT..
- Clutch Kits for 07 Z
- Clutch Problem? Help? TIA
- JWT clutch/flywheel question
- To ALL 08 6MT Owners!
- good willed?
- Revup Oil Problem
- 3.9 final drive on 5at
- Install on 4.08 Gears
- Question on Idle speed
- HOW TO: Install a Walbro GSS342.
- Stillen Valve Body Upgrade
- Gaskets???
- Problems on Cylinder #4
- How to make a 350z faster?
- Duo of questions.
- light weight flywheel?????
- How do u remove the silencer from Greddy Ti-c
- Awd
- Idle Issue (Car shuts off) after Remove Spacer and MREV2
- Motor/ drivetrain Question!
- Nismo oil pump
- Help
- Ebay Oil Cooler
- Installed cusco yesterday.
- unexpected noise
- JWT C8R cams
- 03-06 AT's VS. 07+ AT's
- Questions about my ecu
- 5 AT Shifter Mod?
- tranny gone
- How Do You Remove The Strut Bar To Install Spacer
- Little Squeek/Whisten when throttle added.
- Auto Transmission not downshifting, giving codes P0442, P0456 and P1767.. Help
- RSP CLUTCH..in comparison
- oil ????
- Here we go again!! (reflash question)
- Has anyone tried fuel system cleaners?
- 5AT final drive & Lsd Swap
- P3000 Engine Code. SES Light
- A few Dynoplots VQ35DE, Revup, Cams, Plenums - Info
- "Clunk" noise when shifting 1st to 2nd.
- Horrible Gas Mileage
- Car went into limp mode, now fine???
- I have said this before, and i say it again
- san auto hyper force system
- safe hp ?
- "GT Spec vs Cosworth"
- what do they do with old 06 engine??
- VVEL discussion.
- Considering buying REV UP motor for turbo swap
- Considering buying REV UP motor (is this possible?)
- Help with burning smell
- smog test with test pipes
- NISMO clutch install will void warranty
- Fairly New Z owner...looking for a plan...
- quick question...is this the engine harness? lol
- Question about swap non revup to revup
- flywheel weights
- 2006 with oil consumption? HR replacement?
- 06 oil consumption
- Rev-up Engine
- Break- in for nismo LSD?
- ??JWT clutch and flywheel break- in procedure????
- Check Engine light? 1/4 time
- clutch acting up? need some HELP
- Pivot Ball
- JWT Pop Charger Question
- Did a dyno run today.
- Pulse plugs = 5.2 whp !?
- Oil Change Interval
- Plenum Spacer Info, Help a kid out here
- how bout a v10
- hard time getting in gear.
- Godspeed?
- Chirping noise between 3-5k rpm's
- 04 with transmission problem
- help with procharged G35 air filter- fitment
- Guess What Brand of Oil the Dealer Uses
- Running Headers + Test Pipes?!?!?
