View Full Version : Engine & Drivetrain
  1. Running Headers + Test Pipes?!?!?
  2. Need Opinions
  3. help with valve cover/spark pulgs/coilpacks
  4. Sign of clutch slip?
  5. Taller gears..
  6. Engine won't go much above 4,000 rpm.
  7. Engine noise & tailpipe noise- Bad smell at high revs. help!
  8. Cutting out???
  9. Oil splatter on front of engine..
  10. Nismo Flywheel, Clutch, Pressure Plate
  11. What would cause a drop in idle? F/I
  12. throttle body spacer
  13. What Mod is Next?
  14. I wanna get some smoother shifter
  15. Oil filters cheap! Hurry
  16. Top End!?!?!
  17. Any experience with Fram Tough Guard Oil Filters?
  18. Cusco Lsd Help
  19. 350EVO 3.9 Final Drive Installed on my 5AT: Impressions
  20. Pulley Insall.
  21. 60 miles and boom
  22. Please review my mod list :)
  23. Short Shifter...worth it...?
  24. final drive gear question
  25. Motordyne Plenum Spacer or ACT Flywheel?
  26. So i am thinking of upping the boost (doh)
  27. Lightweight flywheel or Motordyne Plenum Spacer?
  28. rev up and non-revup
  29. Transmission woes. Help please!
  30. Stock diameter of pulleys?
  31. Nismo 06-08 350z Dual Intake Manifold
  32. Engine noise on start up
  33. ONE mod to do UR Pulley OR 5/16 Spacer
  34. Hose question for engine GURUs
  35. 04 trans, new to nissans
  36. Clutch kit
  37. Todays mods:Test pipes, lube
  38. question for people with nismo LSD
  39. STS Turbo cost installation
  40. Responce to the "Chips hmm" thread.
  41. Quick+Easy Q - Radiator
  42. Baseline Dyno...254whp
  43. post break-in oil change
  44. Looking for A/F Guage. .any Suggestions?
  45. Simple auto transmission drain and fill question
  46. Octane Much???
  47. Fuel System Upgrade Q
  48. Drivetrain noise with lighter flywheels - fix?
  49. JWT S7 Cams
  50. chips hmm?
  51. where is the fuel line going into the engine?
  52. Spend under $1000 for performance
  53. Anyone Have A Differential Cooler Set Up?
  54. Second set of Modifications
  55. Upgrades. . .
  56. 6mt to 6mt swap how much?
  57. EXEDY RACING STAGE 1 and act flywheel now hear bump ,help
  58. ARC Pro Choice Diff Cooler Kit
  59. Any experience with Southbend clutches?
  60. Cold Weather Clutch
  61. Belt Size W/underdrive
  62. Is too much LSD oil bad?
  63. Are our tranny's that BAD!!??
  64. Do 04.5's have oil consumption?
  65. clutch going bad?
  66. Ok this worries me
  67. may have oil consumption at 22k im not sure :(???
  68. Tranny issue
  69. 2jz 350z
  70. Need help fast! Maybe...
  71. WTF? bad MPG?? is this normal?
  72. how to determine 6MT transmission revision (one method, NOT asking question).
  73. drilling hole in throttle body
  74. grinding in gears
  75. rb26dett swap still debating?!?!
  76. Cams for boost
  77. Need revup engine pics
  78. what size??
  79. Drivability difference?
  80. Magnaflow with Test Pipes?
  81. crank pulley vs pulley set
  82. Very loud click/clank noise (read) important
  83. Is the Z a rev happy car?
  84. burning clutch
  85. clutch and performance??
  86. VERY NOOB QUESTION...pls help
  87. Hello everyone im new here and need some help
  88. 350Z Oil Consumption
  89. Question about getting test pipes installed
  90. clutch/flywheel issue...need help asap
  91. Code P1273 and dealership woes
  92. Pulse Plugs?
  93. Vq 3.5 All Nissan Stroker Kit...???
  94. Plenum spacer question....
  95. Looking for a taller gear...
  96. I think I'm getting robbed....
  97. If I buy a 4.08 Final drive gear....
  98. ***Dyno Overlay of a 07 and 03 Same day Same dyno***
  99. car preperation for twin turbo kit
  100. Mishimoto Radiators
