- 350JZ finally up and running VID inside
- New clutch and flywheel installed now problems
- Tranny in a 07
- Recommend Spark Plugs NA
- 06 Tranny Whining. My brother bought a 06
- Clutch question
- Smelly Clutch
- Your Thoughts: Modification Roadmap
- Knocking, ringing, diesal sound
- How much is a Rear diff worth from an 06? My
- *delurking* I would like a few opinions
- Rattling noise when turning off engine
- Sluggish in low revs
- 4.2L stroker & passing smog
- I'm at MY N/A Max!!!! VQ35 Guru's needed.
- CVTC/e-VTC?
- engine buzzzzz on then off and back again
- Tune Up
- Will Changing Transmission Fluid Void Warranty?
- whats v1 and v2 motor on Z?
- Z1 Performance now carrying Motul Lubricants!
- How much should 3 dyno pulls cost (just for numbers, not tuning)
- rear main??
- High Clutch Engagement
- Clutch Compatibility Question
- Quick Tranny Question
- Project Underway!! =]
- Need help understanding Cams
- "Slip" light flickering and car jutters
- Replacing Clutch Cable
- How to Drain Oil?
- 06 rev up engine : Rebuild or swap ?
- 350Z performance?
- Nissan Tech! help! =*( anyone
- Base model owners without VLSD, Have you changed your differential fluid?
- Options on 06 engine rebuild ?
- Idler Pulley Assy probs...
- HELP, Air bag lite ON after burping the radiator
- Innovate Wideband Install Wiring (need help)
- Lsd Fd ?
- question about engine overheating and transmission issues
- One last mod (for now), help me decide.
- Clutch Pedal feel
- ecu reseting
- 4.3 stroker kit
- if sleeved...can i use this engine...?
- Most bang for the buck (HP) before going FI??
- How much does a clutch cost on average?
- Where Do I Tap My Boost Gauge Hose
- Need help!!!
- Help With Engine Heater
- NA RevUp Cams
- Bad smell?
- brand new clutch install; weird noise??!!
- standard engine mods
- aftermarket parts
- Issues after Camshaft install.
- ringing noise when pressing on gas pedal
- nismo lsd problem
- Nology Laptop Dyno
- Diesel Power the build
- automatic and higher horse power
- N/A build up
- what size injectors?
- OEM part numbers for 4.083 F/D
- Anyone try these tricks for more power
- Any recommended throw out bearings?
- To those with oil burning Rev-Ups...
- Clutch Question - Slipping?
- Rod Knocking??
- Typical Clutch Install Price
- vq37 and vg35 questions? similarities...
- 3.8L Cosmetic Head Gasket
- Visual difference between Rev-Up and non Rev-Up
- Built 6MT's?
- Tune or not tune lightly modified VQ35DE
- Oil Pan Install Questions
- 4.083 Gears
- Power Cheched My350Z
- quick wiseco pistons question
- VQ35 TT in a 240SX but something different
- N/A Power?
- Carbonetics LSD and 4.083 Gears Installed!
- Need Clutch Pressure Plate and Flywheel Combo
- How do I 'wrap a cable around a ignition lead'
- Quick question
- Zoom clutch???
- f1 flywheel
- smell of something burning
- Blown 06' VQ35DE! Due to Oil Issue
- How long does it take to glaze a new clutch/fly?
- 350Z engine in a Qashqai?
- Project 2JZ in a 350Z by XAT RACING
- colder weather=more hp?
- Good oil for the VLSD
- Torque Specs on Intake Manifold?
- Turbo sizing and other questions
- any RB engine swaps?????
- motul 300v
- Stock engine cover with Stillen strut bar
