- Anyone living with oil cons. problem?
- what else is needed?
- Tomei 264 Camshafts issues
- Does the Lemon Law apply to me at this point?
- Toluene? Just a few questions.
- tt in 5at z
- Help Clutch!!!!!
- how much hp can the stock clutch handle?
- Woah, Cosworth to offer low-compression VQ35DE
- Change Diff gears on 5AT? possible?
- Tranny Problem (Reverse)
- Run in stock mode?
- 2006 rev-up comp. ratio
- Anyone know who makes Nissan`s manual trannies?
- 5at shift shock
- Clutch question...
- Cd009
- 03.5 5AT: Transgo Valve body and Edge Racing TC
- Dyno'd my N/A Auto 350z LOL
- Mod build up question?
- Nissan Clutch Most Sensitive
- How much estimated rwhp?
- 6-speed upgrades?
- RPM Hesitation @ 2300 RPM
- 16 pages of crap
- hydrogen booster?
- Thottle body spacer - Gimmick or real deal?
- MD Spacer + BTDC17 today. Should be interesting.
- So I cut the VDC wire...
- Who's LS1 swap is this? ***PIC***
- Welding spider gears on diff
- Chain dragging noise from motor (Is it the timing chain or detonation)
- Wierd BackFire
- Possible Clutch chatter?
- HKS DLI II ??? does ti make a diffrence?
- Warranty....?
- Can the oil pan be notched?
- LSD Question
- Question about battery/tune
- air cooling and HP
- need a little help
- almost fried my clutch
- What size injectors should i use???
- Revo short throw shifters
- Oil Catch Can Connection question
- Similar manual tranny issues.
- Fuel Pressure Gage Install Question
- getting rid of my a/c
- AAM 2007 350Z Product Releases: Test-Pipes & High Flow Cats +14whp and torque!!!!
- 2007 Base Model Rear End
- Help! My Z won't start...
- engine question
- Check out what I made for the VQ35
- Use a revup engine on a non revup car
- install labor
- Clutch Changed Feel?!?!
- Well MY V8 is in!!! (LS2)
- Burn smell when I punch it
- Cusco RS LSD and Technosquare...
- How Fast.... Is Fast?
- Spark Plugs! :-(
- Click in rear
- Need Help!!!!!!!
- any difference btw 2003 and later model's clutch?
- Cusco oil catch can and other stuff is on
- Oil Catch Can
- Synchro's failing
- Best place to get gear set install parts
- Oil for the 07
- Clutch Slipping
- Gap for NGK's
- Performance Flywheels with Best Driving Quality
- spacer question
- Lightest Aftermarket Flywheel
- question about rearend in 05 auto Z
- Race Track + 07 Clutch Problem = Not Good
- How do i turn off the check engine light??
- Need advice on Clutch & Flywheel
- i think i'm just being paranoid but...
- WTF... "SLIP" light flashing...
- clicking on 6mt
- UR Pulley voltage drop
- Do you have drive by wire?
- Engine Swap Advice.
- Got a funny noise when tranny is cold...
- Ahhhhh, sweet sweet FW
- cusco LSD breaking in
- Topspeed products?
- engine covers
- Steel clutch line for the 2007
- 350z shifting
- Drive shaft
- Arc v.2 catch can installed..pics
- Transmission Break-In?
- Motor swap time!
- tomei camshaft problem help!
- Oil temperature sensor...where to put it?
- LSD Maintenance?
- Flywheel
- Couldnt Get into 5th gear
