- HELP!! AAM Basic fuel return system
- Does anyone have a diagram on the tensioner pulley
- Master Cylinder
- What's my drivetrain worth?
- TPS issues, limp Mode, Need Advice
- HKS Engine Cover looking for interests.
- Knock sensor Harness couldnt get it!! Help plz!
- Nismo Parts no longer made?
- Need help! Hr or de flywheel
- de-hr trans
- Is a Twin Turbo a Good Idea?
- Aluminium valve covers succesfully installed. Part 4
- Clutch pedal has a lot of play all of a sudden
- First 2 Gears?
- Opinion on ebay radiators
- ACT clutch and JWT flywheel problem
- Transmission shifter linkage problem?
- Anyone with Electronic gauges ? HELP**mine don't work
- Yes!! New vq35
- Jim wolf clutch /flywheel question
- Timing chain tensioner
- Not shifting into 3rd at high RPM?
- CD009 Transmission in 03
- loops in clutch line??
- Half rotate engine
- Anyone got a Nissan oil filter that's been cut open?
- P183 and P462! Help please!
- twm performance short shifter
- Pics of NISMO Shifter before installing?
- Can anyone tell me what this is/Does?
- Does it prolong the life of the clutch if....
- first time buyer questions!!
- Built trans debate
- Strange grinding noise with Z1 clutch and flywheel?
- Gears or complete differential
- 7100 RPM Safe for Stock?
- New 350z engine swap advice
- Master Cylinder/ Clutch Slipping
- Clutch pedal return/bleed issues
- HKS to close U.S. operations
- Pulleys.
- auto trans help
- Bad axle? Good axle?
- Suggestions needed (pics)
- Polyurethane motor mounts besides Megan?
- Car won't fire up
- Burnt clutch smell
- Engine Rebuilt advice for Heads on Revup
- Need help
- 370z 3.7 final gear and VLSD on 350z
- hr cams in de?
- ngk cbe4a plug question?
- Clutch & Flywheel
- 350z ECU work on a JDM 03 350GT
- underdrive pully
- Yet another clutch adjustment thread
- Anyone use a Clutchmasters flywheel w/ ACT clutch?
- ART Pipes and UpRev Tune or Quaife LSD?
- which FD gears?!
- Best place to buy transmission parts?
- 5th-6th gear ring baulk
- Trouble with engine
- 2007 MT Base 4.083 Gears with Quaife LSD Review
- CD009 Fitment
- oil change?
- VG30 crank?
- Anybody have Transmisson front cover torque specs?
- Next Best Performance Mod
- DESTROKING is it possible and how?
- what do the oil pressure and 'volts' gauges tell you?
- Condenser on coil power wire
- 04 350z has wrong pivot ball?
- Is this normal clutch behavior
- high gas prices! can I shift from 2nd to 5th?
- VTC HELP!! (varible timing control)
- Oil leak - what to replace?
- What is the gear ratio of this diff?
- Is this Radiator cap any good??
- Upper Radiator Coolant Hose diameter
- i need help...when i press down my clutch car stalls
- NISMO LSD rebuild kit ?
- 2006 clutch clicking
- Grounding Kit
- Clutch/Flywheel issue?
- VDC mod still cuts power
- Error code p0057 o2 sensor question
- Ported Throttle Body
- 580whp fuel problems?
- 03 6mt: grinding sound after cold start
- Aluminum Pulleys=Death to engines!
- Last resort, cannot switch gears cold! help!
- 350Z VDC & EBD Tech
- Stillen underdrive pulleys
- 03-06 Transmission Issues?
- 350z HR cam & crank position sensor wiring
- Fuel Pressure Regulator gone bad?
- Oil consumption question
- 350Z
- location of fuel filter
- Rattling noise
