- what does everyone think about this kit.
- dipstick rant
- For Those With UR Pulleys
- How would you know you have oil consumption?
- Clutch replacement help....
- 03 oil consumption problem
- performance part webcite
- My car feels not Z-ish...
- 2007 Owners With CLUTCH problems
- Clinking noise @ low speeds
- Who doesn't like a 350z??
- LSD for 2007 Z?
- 2007 350z Clutch Problem
- Rattle / Buzzing at 2500 and 3300 RPM's
- looking for pinout wiring diagram for MAF sensor
- Gearing difference betwen 03' tranny and CD009?
- 2006 350Z - Oil Pressure Problem
- Looking for 4.08 final drive gears
- What is a good n/a CAM
- engine builders
- Stroked Out
- Shifter Problem HELP!
- SZM Plenum Mod Shoot Out
- question on clutch
- Smoke during drag run from an 07
- Tranny conversion
- clutch feel completely different with AC on?
- clutch and flywheel combo help
- Upping the rev limiter and power curve
- Warranty: Pressure plate
- Checklist
- Z vs. G head
- Humming noise from rear. What could it be?
- oil
- 07 rpm fluctuating
- What is a oil catch valve?
- 07 base + vlsd + 3.91 gears
- ****Clutch stuck to the ground and wont come back up. (HELP)
- weird sound when in neutral..
- CD009 Stiffer with Age?
- Need Help deciding on new Clutch
- does wrong final gear ratio effect dyno pull?
- Labor hours for mods
- Forged Performance: 2008 G37 Coupe Baseline Dyno
- HELP! Rear end issues, pinion bearing!
- runnin out of ideas..
- Just wanna know if anyone know about this clutch/flywheel kit
- crank pulley?
- Problems with brand new Z
- clutch line and fluid
- Turbonator now only $39.95!!!
- Updated 06 Engine?
- crank pulley removal
- Test Pipes Issue....
- Turbonetics Z after 2k went BOOM!! *PICS*
- Will this O2 sensor work?
- Rev up engine? How to tell?
- Best Port-Polish
- Need help w/ valve clearance on 268 cams
- Stillen 5AT Valve Body Upgrade
- 2007 350Z AAM 3" Single Exit Exhaust 15+hp Midrange Gain!! Dyno Chart & Video Inside
- Warranty Tranny SOS
- "Popping" noise
- Overheating issue, need advice.....
- Will 05 pumpkin fit 03?
- 350z Manual gearbox and clutch wanted
- driveline grinding
- well crap... :(
- Help...Need A/C Pulley Schematics
- So i go to the dealer...
- Diff locking up? new 009 trans
- OPINIONS- Tanabe Exhaust
- Combustions Chamber video
- Clutch+Flywheel upgrade
- Oil and PS Brackets?
- Dynoed and Osiris tuned my car with all my new mods-graphs
- Rattleling noise shifting from 1st to 2nd
- Clutch pedal shudders when pressed in; intermittent
- Top Tier Gasoline - Very Interesting
- Carbonetics Twin Carbon Clutch Engagement problems
- Taking turns question, some unsettling behavior
- nismo lsd
- How to make my car faster?
- Anyone with an aftermarket clutch also modify their clutch travel?
- My 2007 350Z Clutch Problem
- Cylinder Layout
- Needed New Engine!
- help with 350z utec bracket
- 5AT Full line Pressure Modification
- "Clicking" Clutch
- Motor Swap Question
- Trans noise
- 350z Clutch Number 2 has gone again, Any Idea's
- 3.9FD on a 5AT
- Cam question
- When to change motor mounts??
- When I first start my 07 and hit the reverse to go back my clutch growls?
- amsoil xl vs asl 5w30
- RPS Carbon/Carbon Clutch
- ACT Clutch vs. Exedy Stage 1 Clutch vs. JWT Clutch
