View Full Version : Engine & Drivetrain
  1. What do you think/know about Kendall, Synthetic Motor Oil
  2. Guess who's on the cover of this month's D-Sport magazine....
  3. Best LSD For Street Use?
  4. Power Train Issue
  5. Stock '06 5M's are geared for 190mph
  6. Cams????
  7. Can i reuse flywheel bolts?
  8. stock LSD
  9. New Z owner and already Drive Train Issues. HELP
  10. Next Upgrades, need opinions!!!
  11. Break-in Oil Change Procedure Question
  12. Need help 8.8:1 and wont start
  13. Another noise/clutch question
  14. Top Tier Gasoline
  15. Nismo LSD HELP!!!
  16. Flywheel Question
  17. Nismo LSD
  18. Help
  19. 07 Test Pipes CEL, Non foulers don't work: FIX? (Read)
  20. Big problem with clutch/throwout bearing on a G35.
  21. new trans popping out of 5th gear.
  22. Re: Synthetic Oil (i.e. Mobile1) and Fram
  23. 6 Free and Cheap ways to add a little more HP
  24. problem with my clutch
  25. Checking wheel bearing
  26. anybody know how to remove u joints
  27. Well, it finally happened...
  28. Carbonetic LSD issues?
  29. need help getting nismo parts
  30. Differential gasket???
  31. Anyone using an aftermarket clutch with a modified clutch travel?
  32. Popcharger/CAI question
  33. Engine Rust?
  34. Wheel size and dyno numbers
  35. how would you make your ten sec. z
  36. 07 fuel cut off?
  37. New stuff is on *pics
  38. Clutch question
  39. nissan oem oil filter
  40. Base Pumpkin
  41. Need Opinion - Who has swapped pumpkin?
  42. Question about spark plugs, wires, and other tune-up parts...
  43. oil catch can questions
  44. Exedy Clutch for 05Z
  45. Is the JWT clutch heavier or lighter than the '04's stock clutch?
  46. Got my 07 back from Nissan after they hopefully fixed my clutch issue...
  47. 07 Enth Tranny Replaced 5th 6th gear feel different?
  48. My oil pressure is high on my new Z.
  49. 5AT Owners Read This: A detailed look at the 5AT trans in the Z/G
  50. Nismo LSDs
  51. The Z's max power..?
  52. final drive question...
  53. New Clutch
  54. ATE Super Blue for clutch?
  55. weird squeaking sound .....maybe clutch
  56. Would you buy used?
  57. who can give me more info about greddy oil
  58. who can give me more info about greddy oil
  59. 350Z o2 SENSORS
  60. Question about Walbro 255 fuel pump
  61. Question about oil weight?
  62. My 6sp manual transmission completely seized up
  63. automatic trans owners
  64. drivetrain warranty voided?
  65. research got me confused LSD
  66. aftermarket clutch for the 07 z
  67. Oil catch can for 2007?
  68. 03 350 owners
  69. Mobil 1 oil viscosity
  70. JWT Utec Base map
  71. ABS System Starts Hopping and SLIP light is on?!
  72. Engine service soon
  73. Filter with synthetic oil?
  74. A little info on 07 Z......
  75. 350z manual conversion wanted
  76. First mods! clutch/flwheel, pulley, test pipes
  77. Dude selling engine scared my grandma...
  78. Auto mode pulls better than MM??
  79. New Engine just installed in 04'...Does Break in apply?
  80. Rattling noise? - '07?
  81. BuiltZMotors destroying axles...part II
  82. fuel pressure while idling qusetion
  83. 2007 Clutch/Slave Cylinder Issues w/ pics
  84. Dyno's, The Truth!!!
  85. D.I.Y. - Transmission Swap?
  86. oil consumption = no modding
  87. possible transmission issue?
  88. 500RWHP Clutch Options
  89. Consumption oil issue after install spacer
  90. Changing Transimission and diff fluid.
  91. Where are the battery threads?!! &#%@&!
  92. 07 manual trans noise update!!
  93. Pyro location
  94. Cost to install
  95. Mobile 1 15W50 extended performance
  96. Whats the difference between the HR, and Rev Up models?
  97. flywheel issues/debate PLEASE HELP
  98. You Got to be kidding me
  99. Question on camshaft...
  100. Has anyone swapped an 07 rear diff?
