View Full Version : Engine & Drivetrain
  1. Help needed sourcing a MOCAL adapter fitting
  2. Like Clockwork!!!
  3. decisions decisions help me decide
  4. Adjustable Cam Gears
  5. 350z Speedo Sensor
  6. Aftermarket Clutch and Flywheel Chatter/Rattle Poll
  7. question about 350Z
  8. questions on full build with tt setup
  9. My car is home, after the dealer and Nissan worked to correct the clutch pedal issue.
  10. My First dyno on my Uk Gt!!!
  11. IS this right?
  12. fifth gear popping sound
  13. Question about break-in
  14. Help A/T Problems
  15. idling sort of rough
  16. Is Motul RBF-600 okay for clutch fluid?
  17. Sick Of Overheating!
  18. Did the Motul Gear lube switch
  19. Towing car in first gear, bad for motor?
  20. Help me diagnose...
  21. gay dealership
  22. Aftermarket Lsd + Dealer = ???
  23. Hit Speed Bump = SES & Dead Car -- Any Opinions/Help/Comments?
  24. 5AT to Manual tranny swap
  25. Nismo Pilot Bearing discussion...
  26. Stock clutch, and pressure plate
  27. my 2007Z with blown slave cylinder
  28. Z1 Motorsports Poor Quality & Bad Service! (BEWARE)
  29. what mod next thats < $500?
  30. 06 Tranny Whine in 6th @ 80MPH
  31. JWT(?) Clutch & Flywheel Combo.
  32. 07 weird tranny/gearbox/clutch problems/questions
  33. I think my friend burned out my clutch
  34. Quick Question
  35. Project ARC..Engine bay build in progress..
  36. What Shoulb Be My First Mod
  37. Base needs LSD
  38. checking the oil LET THE FLAMING BEGIN
  39. question after 3.5 FD swap
  40. Anybody do a wire tuck yet?
  41. exhaust rattle?
  42. building engine
  43. Driveshaft Shop-Thanks for your excellent customer service!
  44. The Nissian Fight
  45. ATS Carbon LSD Help
  46. look what just came in the mail from Z1
  47. Just installed crawford HFC's and Vibration/rattle
  48. Clutch Installed Backwards?
  49. Girlfriend bought a Z yesterday...
  50. Which Z's have AT /w Manual?
  51. 2007 2nd gear?
  52. So many oil threads!!
  53. Royal Purple or Amsoil?
  54. Differences between VQ engines..?!?!?
  55. Is this true (can't heel & toe on '07)?
  56. G35 sedan differential info
  57. Serious flywheel install problem--please help!!
  58. made some mods to my valve covers.......
  59. Engine Build: Guide
  60. CLUTCH QUESTION - Help plz
  61. engine question
  62. just got my new tranny
  63. strongly considering FI: goal being (400rwhp)
  64. Another losing oil thread... not a revup motor
  65. Drivetrain Weaknesses
  66. NISSAN 4.083 Ring And Pinion ???
  67. ECU code - not on the list, i checked :D
  68. do i need a new clutch?
  69. 2007 - Engine Hood Very Hot to the touch
  70. Car makes strage sound when going over bump after strut removal?
  71. Need Info..auto pumpkin swap???
  72. 350z gear box?
  73. Does the Cooling plate help that much?
  74. 2003 Oil Victim
  75. Twin Turbo Questions
  76. '06 Z Clutch & Flywheel questions...
  77. need some help~~
  78. Help Me
  79. Pulstar plugs?!
  80. Finding the love...
  81. What kind of performance chip?
  82. shifter question
  83. 03' oil problem
  84. UR Crank Pulley Belt Squeal
  85. Clutch High Engagement Remedy - DIY
  86. GTM HR Stroker Update
  87. Anybody ever seen this radiator?
  88. Losing Oil
  89. Gonna change the oil this weekend on my 07
  90. Clutch redesign
  91. Nismo LSD question
  92. Open Advice on engine build
  93. 5AT with 3.7 final drive?
  94. Car stalled out for first time tonight.
  95. 3.9 gear ?
  96. TCS vs VDC
  97. Is my motor dead?!!
  98. Major engine knock on start up
  99. Lightest clutch + flywheel combo?
  100. rev-up swap into non rev-up cars??
