View Full Version : Engine & Drivetrain
  1. Why is a lightweight flywheel and clutch better??
  2. bullet proof 6 speed
  3. Spec stage 2 Clutch & Lightweight Flywheel Question
  4. JWT FLYWHEEL clutch Question
  5. "SLIP" in 4th?
  6. SVRT is NOT VRT
  7. NEW TRANNY :) clutch replacement?
  8. Any visual difference between 04 and 06 engine?
  9. Good price quote for install?
  10. what's the easiest way to add hp to my new Z
  11. Why isn't this Valve Body working?
  12. 07 lots of weird problems all at once
  13. G-Tech Meter used to gauge mods
  14. Whining?
  15. what is this sound....
  16. Help with Upgrades
  17. 4500 Miles to soon for Synth. oil?
  18. Fuel Pump +
  19. Random Overheating??
  20. soft clutch
  21. oil pressure
  22. Rear main seal..
  23. What is this vacuum hose?
  24. How difficult would it be...
  25. Forged Performance: Live Report from the Bonneville Salt Flats Speed Attempt**Live
  26. Changin diff. oil and tranny fluid!
  27. Fly Wheel and Clutch upgrade
  28. ATTN: 2003 owners still on 1st transmission..
  29. Unorthodox Racing Pulley Sets
  30. Osiris as Launch Control or two step rev limiter!
  31. Need More torque
  32. Throttle lag?
  33. Where can I buy 350Evo 3.9 gears
  34. Post Pics And Vids Of Your Custom Exhaust
  35. Oil PSI at idle
  36. 2007 Modifications ???
  37. clicking axle"
  38. Wtf @ Oil Leak.
  39. So I took my car in for the 07 clutch pedal drop issue....
  40. New OEM clutch disk bought...
  41. Decel Vibration Right At 2200 Rpm..??
  42. $15,000 Budget - What to do?
  43. I'm confused
  44. RB26 Swap...final decision
  45. How stiff should the shifter feel?
  46. Logging both Air Fuel and RPMs in pre 04.5 cars
  47. 3rd gear grind?
  48. New Radiator
  49. S/c Bov Valve??
  50. Requesting Feedback on the Forged Performance Valve Body upgrade
  51. 07 exhaust on 06
  52. Aftermarket radiator arc vs greddy
  53. Just had a new tranny installed... Wow! ...What a difference!
  54. Anybody do a 5AT tranny fluid flush/fill?
  55. Looking for Va= Hampton roads group
  56. tranny vibration problem
  57. Pigtail for the oil pressure sensor - wire colors/routing question?
  58. Front vibration problem
  59. Engine Whining?
  60. oil leak!?!?
  61. How much to install....
  62. Blah!
  63. JWT TT perform at E-town 12.6@112 and 12.8@112
  64. New Idea for oil cooler mounting location
  65. Installing oil cooler missing a piece, hlp plz
  66. Noise at startup
  67. Torvec Iso-Torque diff
  68. Need help with a decision.
  69. Ticking axle
  70. HELP w/ Engine not starting at times....
  71. exhaust leak
  72. Rattle on startup...?
  73. Engine Stays HOT!
  74. Death on the highway
  75. Swaping Trans
  76. Need help with a problem my tuner cant figure out!
  77. I'm Glad the HR is a carry over for 08
  78. Yay ! It looks like TS ECU Resetting Procedures work on 07 !
  79. How to increase rev range?
  80. Oil on the back of my car?
  81. Project Choice: Skyline Engine Swap? Aftermarket Twin Turbo?
  82. Soft rev limiter 05 Z?
  83. 07 Z redline question
  84. Question about TC and LSD
  85. LSD mind boggle.....
  86. Transmission help
  87. AT Fluid Hose Diam
  88. I'm sick of the VQ!
  89. Rear End Noise
  90. Recall on the 07 JDM Z Edu?
  91. carbonetics twin disc noise?
  92. too much oil? Help
  93. Engine gets louder after 5000rpm
  94. New Flywheel a Must for New clutch?
  95. Severe Engine Braking
  96. Squeaky noise--clutch
  97. Best tool(s) to measure temperature of engine bay, brake caliper, rotor, etc...
  98. Who can install a quaife diff in my pumpkin?
  99. ACT Clutch + Flywheel combo from mynismo
  100. Tranny
