View Full Version : Engine & Drivetrain
  1. Best LSD?
  2. Another VRT and MR. A thread
  3. JWT Combo or CM Stage 4/JWT Flywheel?
  4. Direct Injection?
  5. VLSD install
  6. Short Shifter Install Help
  7. Dynoed my 07 5AT today
  8. Overheating issue at MAM roadcourse! HELP!!!
  9. Bad Coil Packs ? - Help
  10. Popping exhaust and rattling tranny?
  11. new 350z tunning
  12. Oil
  13. Bureau of Automotive Repair (BAR)
  14. Help: About to take on BMW M6, SL65 AMG, E55 AMG,M3 with NOS, Audi RS4
  15. Wiring harness question
  16. Craftsman torque wrench?
  17. Advanced Timing/BTDC via Consult II TOOL?
  18. ACT VS JWT Clutch and Flywheel Combo
  19. Update: My Build, Ultimate Goals & 1 CRAZY Day in Utah
  20. Confirmed it...current 03-06 aftermarket diffs fit the 07!
  21. What does brake boosting/loading physically do TO the 5AT?
  22. What does Brake Boosting a 5AT turbo physically do the transmission?
  23. Removing Engine and Installing Greddy TT
  24. PINKS - What Vendor / Tuner has the SAND?
  25. New clutch and flywheel to be installed at dealership....maybe..
  26. Oil question
  27. 2007 350Z - Is it possible for the clutch to stick 'down'?
  28. TDC at compression stroke?
  29. check engine light came on... 400miles till oilchange due, that the cause?
  30. General question about SAE and 350Z HP ratings...Why 287HP?
  31. Loud cement mixer noise in 1st gear (06)
  32. clunking noise from my 07!!
  33. Starting to Mod my Z
  34. Tomei Rods...anyone have a built with them?
  35. Clutch Cable replacement
  36. How can you keep engine temps down?
  37. Another Tranny of Death Thread...
  38. Stroked NA
  39. 350z motor swaps
  40. problem entering into 5th gear
  41. Revup & spacers, any truth to the HP claims?
  42. I think my power steering is leaking?
  43. What to do first
  44. Wet NO system
  45. smoking problem
  46. Possible signs of problems? Might be running a little sluggish?
  47. does brands of gasoline matter?
  48. "Clutch Shudder" question
  49. HKS grounding kit installed...surprising results!
  50. Is my tranny going?
  51. Is all wheel drive a possibilty?
  52. help! car won't start
  53. short shifter problems
  54. ??? Who has the houdini 5th gear ???
  55. wont go past 2.5k rpm
  56. Removing Timing Cover
  57. Spark Knock
  58. Changed Plugs = Fuel Consumption Increased by 15%... HELP!!!
  59. Not using the heatshield air duct screws on pop charger?
  60. My TT experience and UTEC
  61. 07 free reving
  62. High-pitched sound from engine compartment
  63. What OBDII scanner to buy?
  64. Weird check engine code (P1057)?
  65. what after the gear rebuilt.
  66. newb question: what kind of lsd does 350z have?
  67. Z is overheating after coolant change
  68. The Under Engine Plastic Cover?
  69. Auto Tranny Making Strange Sound!?!?
  70. Operation "Cool Running" is in effect
  71. serious question...no laughing! lol lol lol
  72. Disengaging first when moving rpm drops below idle
  73. clutch pedal question
  74. Ordering Oil Online
  75. attn: engine builders.....best valve spring compressor???
  76. My Z is sick...
  77. Built VQ or RB26
  78. Mityvac - Anyone own one of these....(links)
  79. XO2 True Dual Exhaust + F/I
  80. Issue With JWT, Flywheel Install??
  81. Opinion of Kendall motor oil
  82. spark plug change
  83. Tranny Whine
  84. Manual Transmission Whining
  85. Problem with stock clutch
  86. Dyno sheet
  87. what fluids have you guy tried?
  88. My car died
  89. Nismo LSD, 3.9FD ... please help, thx u~
  90. Roaring noise - is it the diff?
  91. how many quarts in an 07's motor
  92. 07 twin intake turbo kit
  93. Clutch acts very Strange!!!
  94. 2007 Trannmission issue.
  95. Clutch Replaced with JWT
  96. WHAT THE HELL? Strange Cut-out at low rpm?
  97. Need help validating the diagnosis of dealership
  98. Finally a lightweight battery...
  99. i m going for NA -APEXI pwer fc ???
  100. Stock Z Needs Clutch - Stock Clutch Assy OK?
