View Full Version : Engine & Drivetrain
  1. Clutch Break In
  2. its that Time
  3. Checking oil consumption on 2006
  4. ARC oil catch can (v.2)
  5. Aftermarket clutch and flywheel swap
  6. Weird grinding going on
  7. central 20 3.9FD top end
  8. 7,845N·m(800kgf) clutch clamping force is equal to what HP?
  9. engine break in questions
  10. Is this the proper Royal Purple
  11. Sticking Clutch - 350Z/G35
  12. crank pulley help asap
  13. JWT Flywheel and ACT clutch
  14. Aftermarket Radiator
  15. Installed both belts in 5 minutes..plus more pics of Helix V2 test pipes install
  16. OMFG 36whp with a strut bar and test pipes!!!
  17. 3.9FD installation parts?
  18. Need Help! Battery Tender???
  19. Shifting into 3rd. Help!
  20. built motor hp and $$$$$ question
  21. Clutch Going? Disengages far from the floor??
  22. question about lower mpg after added mods
  23. Knock Sensor
  24. 2007 MT Tranny Whine
  25. gray smoke......
  26. Trans grinding into 3rd
  27. connecting hose from catch can to PCV
  28. Improving throttle response
  29. clutch disengaging
  30. Transmission grinding into 6th
  31. Oil Consumption List Only
  32. How to make HR power with a DE - insider info from NISMO
  33. motor swap to rb26dett
  34. ARC oil cooler, oil pan, micro radiator on NA Z/G
  35. Alright, need troubleshooting for "smoke"....
  36. Question about Auto Tranny Coolers.
  37. *ATTENTION* MY350z Veterans: Help me make a good "sticky" thread
  38. which disc?
  39. Please help with my 2005 Nissan 350z
  40. Throttle cutting...
  41. VQ37 Dynos @ 287WHP/236WTQ
  42. un pully issue... for un pulley owners!!
  43. gogo VOTE!
  44. Took me 6 hours to replace a tranmission
  45. Help with Greddy RC440 injector install!
  46. Crank modding
  47. Grounding kits..
  48. C's short shifter, anyone?
  49. Hi - low radiator fan speeds
  50. stroker kits...
  51. Engine Fogging
  52. help on next mod?
  53. Diagnose this:
  54. JWT clutch combo
  55. smartest mod?
  56. Need a Recipe for 400hp
  57. just got done changing diff oil
  58. Final Drive 3.5
  59. gas mileage
  60. Head and Cam swap
  61. New to Z, checking oil level
  62. Y-pipe back needed?
  63. Octane boost / Jet Fuel / Other Mixture Types
  64. O2 or bust!
  65. very bad hesitation....
  66. Fitting a Built Short Block- Whats to do?
  67. secent money and not sure where to put it
  68. update on 07 clutch problem
  69. REAL Performance Chip 350z??? (ebay)
  70. 3.3/3.5 Pumpkin and Stock VLSD ????
  71. How would you spend $1000 on a stock AT Z?
  72. Replace Stock Gauge
  73. Nissan techs, I need you.
  74. Radiator Cap What bar?
  75. Project Car Stage 2 - MREV2 & 5/16 inch spacer
  76. Ideal pump gas compression?
  77. 373 Gears??
  78. unorhtodox pulley
  79. problem with acceleration, possibly clutch???
  80. Tomei Oil Caps - all colors *in-stock*
  81. Engine Removal
  82. Engine Removal
  83. braille battery - issues?
  84. jwt clutch & flywheel wont work after install.
  85. Retainers and raising rev limiter
  86. royal purple...power loss
  87. Brian Crower @ Intense Motorsports
  88. weird noises, is it normal?
  89. bumping noise
  90. 2007 LSD question - Attentio sponsors!
  91. Danger running hazardously lean?
  92. Tranny #5 Oh Yeah !!! CD009
  93. Noob question sorry
  94. 07 z issues
  95. K&N Oil filters
  96. Carbonetics cutch install!!!!
  97. Axle Carnage!!!
  98. Do i need a tune/ reflash?
  99. Braided Clutch Line
  100. Quick question about the mass air flow sensor
