View Full Version : Engine & Drivetrain
  1. Well I snapped an axle
  2. Grinding noise after Quaife LSD install?
  3. 350z short throw shifters...ebay any good?
  4. Royal Purple Fluids in the Tranny and Diff
  5. Royal Purple Fluids in the Tranny and Diff
  6. Cracks or just Casting marks on engine?
  7. Input on Header(s) & Exhaust UPGRADE
  8. Engine check/ coil pack sensor problem
  9. Clutch Problem
  10. Short shifter?
  11. P0300 Random Misfire after engine rebuild
  12. Rattle when excellerating
  13. NRG Grounding kit
  14. comptetion stage 4 clutch&flywheel grinding.
  15. Engine Dress up
  16. Need Help! Knock sensor code.
  17. Anyone using an finned oil filter cooler?
  18. Wheel bearing....
  19. Engine response question.. Lagging
  20. cams question
  21. Got my oil changed today because it was really cheap...
  22. Problems after JWT combo install help
  23. Blown head gasket? Help!
  24. Needing to replace clutch in my '04 Z, price help?
  25. What is on the inside of my oil cap??
  26. AMS 52mm rad....good fitment?
  27. Do all G37's have 3.7FD?
  28. Excessive oil consumption
  29. cp piston direction?
  30. Clutch Advice...Please help
  31. OBX LSD diff
  32. alternator plug
  33. engine bog
  34. hks exhaust will it fit my 07HR?
  35. anybody here with ebay torque dampener?
  36. FI or N/A to keep reliability? and 1/4 mi expectations?
  37. need help please asap
  38. Pinion flange help!
  39. oil consumption mineral oil vs. synthetic
  40. UP-Rev tune with Dyno Results - 2007 350Z
  41. draining and removing air conditioner - a/c
  42. Regular unleaded gas/ sluggish motor
  43. Cams question.
  44. acl thrust washer Q
  45. Nismo Clutch for 2006 Z
  46. Installed new Clutch. Car cranks 3-4 sec then starts
  47. V8 350Z. my 500+rwhp goal
  48. Tax Refund Check: New Clutch?
  49. Tranny grind every gear still unresolved help me
  50. JWT Valve Spring & Shim Kit with OEM Cams?
  51. Modified aluminium valve covers. Part 3
  52. Need Help Deciding INTAKE/EXHAUST
  53. 350z and G35 Sedan, same auto transmission?
  54. Stock VSLD questions - 2007 Touring
  55. another "ticking" thread...with vid
  56. Cosworth Oil Pan Baffle Oil Control Baffle Install Kit
  57. quaife or carbonetics Limited slip diff????
  58. Impressions on my TWM shortshifter kit...
  59. JWT vs OEM
  60. Help with Valves and Compression mods!
  61. 2006 350z new V2 motor installed!
  62. Parked on incline in 1st and car rolls back
  63. New motor installed - Rod knock? (Video)
  64. possibly running to lean
  65. Cryo Treating Gears?
  66. Help Need to Identify clutch brand: Cynrg Clutch?
  67. Crank "snub" HELP!
  68. Clutch replacement?
  69. Need help deciding on clutch/flywheel setup
  70. Thanks For towing then frying my Z - Please help!
  71. Knock Sensor replacement how-to?
  72. Cabon Fiber Radiator Cooling Plates that DONT fade
  73. Swapping a VQ35DE for a RB26DETT
  74. Quaife LSD Break In Before the Track???
  75. Tilton clutch and flywheel?
  76. cruise control and air bag
  77. Halp!
  78. First time on dyno with wierd results. Please explain!
  79. P0035, no spark, new sensor
  80. Motordyne gasket question
  81. eBAY TURBO?!?!
  82. New Fuel pump
  83. idler pulley missing??
  84. Tach/RPM signal source?
  85. vlsd pumpkin swap
  86. Fuel Damper Direction
  87. Help Needed, car won't start
  88. OBDII Reader
  89. RB26DETT 2007 350z swap
  90. HR trans help
  91. Loud air escaping noise
  92. Help please
  93. is reving my engine bad ? sorry newbie asking
  94. Going out on a limb, buying another track 350z project!
  95. Will the god of 350z's help me..
  96. power steering pump
  97. Dynojet SAE vs Uncorrected Issues?
  98. car wont rev past 2k RPM..
  99. Do 4.08 Gears Require Oil Cooler or Supporting Mods?
  100. Operator, I just drank seafoam. Is that bad?
