View Full Version : Engine & Drivetrain
  1. Record for most HP lost...
  2. Oil catch can install
  3. Help.oil fouled.
  4. real rich
  5. Technical catch can connection question (not the same 'ole one)
  6. Which synthetic MT fluid really performs better than stock?
  7. HELP NOOB!! Difference between 05 and 06 performance
  8. Yet another clicking thread, but this seems different
  9. Transmission not on warranty??
  10. VRT Building VQ for Sport Compact Car!
  11. help!!!clutch stuck to the floor!!
  12. the best clutch for stock Z
  13. Mixing different brands of oil..
  14. Intake, MREV2, Spacer & More... no perf
  15. 3.9 Final Drive Install - But do I NEED An Install Kit?
  16. How do I know??
  17. 'hiss' pressure release-type noise after engine-off
  18. HELP!! Complete loss of power!
  19. Oil Catch Tank
  20. Forged Performance Open House/Dyno Day Vid
  21. 03 350 Power Loss
  22. Tranny Problems / Clutch Slipping & More!
  23. Broken in yet?
  24. 2006 Oil consumption issues
  25. 2004 & CD009 Tranny Question
  26. Clicking Sound from the engine I guess!!!!
  27. Sleeve bearing
  28. Where to buy SS Clutch line? Does brand matter?
  29. Please Help: Car Won't Started
  30. ARC Oil Catch Can V.2 Installed!
  31. Rims or Quaife LSD and Beat?
  32. What's with my boost gauge?
  33. 3.9FD_04 OD casing_04 VLSD carrier...problems?
  34. $90 for oil consumption test???
  35. Im not a Noob, but do I need this part on the car?
  36. transmission
  37. waiting for 07 mod's
  38. Castrol GTX 5w30 for everyday driving
  39. Ultimate Racing Cats Impressions...
  40. Just arrived (ok yesterday) Nippon Eneos 5w40
  41. Pedal Drop
  42. Z newbie looking for oil recommendation
  43. Is it the tires or the rear end?
  44. 03 trans 4 sale
  45. need help/suggestions
  46. This may sound like a strange question, but...
  47. Does your clutch ever stick to the floor?
  48. Is my Z idleing low?
  49. Can this be fixed?
  50. Need Help ASAP *Quick question about drive belts*
  51. Pleas Help Car Wont Start Now.
  52. Kinetix V+ rubbing hood...
  53. This nappy headed thing BLEW!!!!
  54. Thinking about UR Ultra S Crank Pulley: Set or Crank?
  55. Should I reset the car's ECU if...
  56. Looking for flange for HKS SSQV...
  57. 07 hr motor swap?
  58. Cool Intercooler
  59. Looking for JWT Vendors
  60. Quick question...
  61. My Car Died
  62. Traction Control
  63. Please Read!! Emergency!
  64. Oil Problem
  65. Let's see your painted throttlebodys!!
  66. clutch for FI?
  67. Our Dyno Dynamics AWD installation process
  68. any more bolt ons?
  69. oil cooler setup
  70. Dyno chart..
  71. LSD Chatter???
  72. Which Clutch should i get?
  73. How to break in LSD ?
  74. Engine weight
  75. 350evo 3.9 and Central 20 3.9 ????
  76. Help needed. Tomei cams
  77. Clutch: More plates more life?
  78. Anyone With Cusco Rs
  79. Hey guys Newby to the Z need advuce
  80. Central 20 - 3.9 Final Drive Installed
  81. 2006 Oil Consumption Question
  82. Does the Greddy Evo 2, fit the car the 07 Z without modification?
  83. Need a good clutch
  84. humming noise coming from motor
  85. Spinoff of Audible Mayhem's 305HP thread
  86. OS Giken Goodness
  87. LSD into base model Z
  88. What are your impressions on the Tomei LSD?
  89. Flywheel dimensions?
  90. Engine Bay Finally Done
  91. Start-up Issue: Stalls out when warm and not given a little gas/throttle...
  92. i am a noob :]
  93. Paddle Shifters
  94. 305 hp NA !!
  95. what should i install
  96. N/A vs FI Parts
  97. To install or to have someone else install
  98. Wich Stroker Kits are better?
  99. irregular idel...
  100. Laser platinum spark plugs
