- 10mm Bolts
- Nissan Tech Line?
- 07 Z, needs FI?
- Hp & Tq Differnce B/t Ur Pulleys
- J-Spec NA build
- Any way to avoid aftermarket pulley squeal?
- Quick tranny question
- How much damage?
- 5/16 spacer
- NISMO Super Coppermix Twin Plate Clutch Z33 V35 VQ35DE
- Still Confused On What Oil To Use
- shiftknob vibration at idle
- Vq25hr???
- Question for all Z owners about coolant system
- New transmission -> Weird shift pattern
- Install kits for 3.9 Final drive
- help! weird smell from under the hood
- VQ35HR combustion chamber volume...anyone know it?
- 350whp to 450whp possible with........?
- How quick can you shift into first?
- after installing ACT clutch and flywheel shifting got notchy
- Pre fill Oil Cooler before Install?
- Mixer sound....while driving.
- Instructions for HKS Oil Cooler
- Retapping a hole
- Variable Valve Timing Research
- Noise during first 30 seconds after start up
- Power differences in years??
- Crank pulley fugged up!
- LSD install in sw FL?
- Colored serpentine/drive belts
- So i bought the JWT clutch/flywheel, should i.....
- Rear differential leak??
- JWT clutch = Exedy Stage 1? / JWT Flywheel = Findanza?
- NUB question
- Need help guys!!! Z wont start....
- VQ Oil Analysis and Info
- VQ35HR vs. 2GR-FSE
- Bleeding coolant?
- Oil pressure change with new filter??
- Car dies on startup!
- am i limpwristing nuts on the torque bar
- How much Horsepower on stock Engine?
- Clutch problem?
- oil pressure
- Using the Multi-Gauge
- how many quarts?
- Getting the UR Crank Pulley. Do I need new belts?
- Transmission Fluid Flush
- squeaking clutch...??
- Someone HELP me out! Ahhh!!!!
- 2007 touring might need new tranny.
- Best oils, lubricants?
- VQ37VHR goodness
- Rear diff whine on 2006 6spd
- NO REGRETS:What mods you HAVENT regreted/changed and why
- connect the dots...
- Pinion and ring A/T
- Engine shuts off while i'm driving
- what aftermarket clutch would be good for 06 350z?
- Just replaced clutch master cylinder and this happens..
- Quaife install
- Can anyone verify this engine harness plug? *pics inside*
- blew 3rd gear....
- Nismo - Super Coppermix - Twin Plate Clutch
- Another ACT Clutch & Flywheel thread
- Resurface stock flywheel? questions
- Rev-Up Oil Consumption Resale Value
- Nismo Pilot Bushing
- headers and pully or just pully
- headers and pully or pully
- 2007 Z - Wierd noise
- Powershifting Funny
- New Transmission
- Central 20 3.9FD
- Engine upgrade VQHR
- Anyone know why you would replace the stock fuel line?
- cams tuning
- iridium plugs
- 206hp yay
- Dyno'ed my mostly stock '06 touring 6mt today...
- Greddy E-01 and Valentine 1 owners
- Oil, 0w-30?
- 2006 oil consumption poll - please vote!
- Need some help guys!
- REV2 Install - Cooling Valve Install
- New Clutch and Flywheel - chattering
- Air Condition line for Turbonetics ST
- Kudos to Andy@Performance
- L.S.D becoming a problem
- Royal Purple question..
- New Clutch Setup (Nismo clutch/JWT flywheel)
- Those of you with tranny replacements.
- need to know mods for 07 350z
- HR swap into previous years?!
- Oil change poll
- bizarre tach behavior
- '07 == new oil dip stick
- 07 z break in
- Idling rough, normal/not normal?
