- My 03' now has an 07' Tranny
- synthetic oil after how many miles?
- My 350z Performance Modding Help/Opinions?
- OMG! 2007 dead clutch
- what year is ok to get a tranny from?
- Why is 1-2 gear so loud!?!??!
- MRC Motorsports Customer service review.
- ACT street clutch/ACT Pro Flywheel review
- How does your clutch feel?
- Function:TUNED Website NOW ACTIVE!
- gauges. HELP
- gauges. HELP
- 2005 z's have oil consumption problems
- VK56DE Motor Swap?
- Auto trans fluid
- Clutch pedal to hard?
- The first: Ogura Racing Clutch =)
- Car died out while driving.
- Well my car shipped out today!!!
- which would be the best next mod....
- greddy oil vs royal purple
- Help please with OBD diagnostic software recommendation
- (Nismo)Transmission the cement grinder effect
- Question about mating companion flange on driveshaft
- Central 20 3.9 FD....where to buy??
- Whats the Average Dyno # for a stock 03?
- Need New Clutch
- 350z vs g35 plenum cover
- Basic Definition of Non-Revup vs. Revup
- tranny swap
- Anybody has the SGP fully built tranny yet on their car?
- Throw-Out Bearing
- Review of GT Motorsports Exedy Twin Carbon Sprung Hub Clutch and Flywheel
- from auto Z to manual Z conversion
- Dyno #'s for my Stock 03 Track...
- sea foam?>>>> feed back
- Clutch characteristic
- something wrong with my clutch?
- Engine stumbling- will idle but not rev
- Torque converter
- VQ35HR ECU MAP Releases...
- install review Top Speed engine Dampener install review
- new Tomei products!!!!
- My NA Project
- Is the Z32 Twin Turbo clutch an option for the 350z?
- Fuel problem please help
- Clutch chatter normal, even when new??
- Drive til 3000, or change oil now?
- Which belt for Unortodox underdrive pulley?
- question on gas
- Another 06 Revup dyno w/ mods .
- are automatic 350's the only ones w/ tranny problems?
- Unorthodox Pulleys...
- Getting My Tranny Replace =D
- Ethanol Z???
- diff cover install?
- tach question
- 03-06 Engine dynos
- Will bigger injectors make any difference on N/A engine?
- Catch can that you can open up to get to internals?
- '07 350Z and '07 G35 Engine Pics
- 400whp? is this possable with stock internals?
- Does Anyone Use "Sythitic Blend" Engine Oil
- ABS not working at all after dyno?
- CARB Decals . . . ?
- Engine not running on all 6cyl
- Motor Oil
- Horsepower!!!!
- Piston Bore Size
- favor please ;]
- Do stock bore pistons need any machining?
- 07 6 spd dyno jet dyno #'s
- Issue with dealership will to fix 03' transmission grind
- "Thumping" with auto shifting?
- 5w-20 oil
- New clutch, requires changing the flywheel ??
- Mobil 1 Oil Users - Motor oil discussion thread
- 3.7 FD w/ Open Differential
- ACT flywheels: ProLite or StreeLite?
- 2006 5AT Downshift Rev Matching
- When is the best time to switch to synthetic?
- clutch parts
- Kinetix V+, 350z Cover, NOS motor shots
- Help! Nismo Ti shift knob and know wont stay in gear all the time1
- Having trouble deciding...
- Vortech 3.12 pulley and a 3.91 Gear
- Need Help
- Just got new tranny and clutch, do i need to break it in?
- I keep hearing all these oil consumption problems
- oem clutch life
- N/A mods.
- Final Drive Ratios
- P0447... AHHHH D@MN Evap Vent Valve!!
- Question about auto tranny power loss...
- engine noise
- Any difference between 04 Valve Body and 05 Valve Body?
- lightweight flywheel for daily driving
- stock clutch fried?
- Which Purolator?
- way to break-in a car
