View Full Version : Engine & Drivetrain
  1. Crooked hood after plenum install
  2. 05 Rev-up question
  3. Sprint Booster anyone?
  4. Factory hp loss to drive train? Any stock dynos?
  5. "Mototune" break-in... is it too late?
  6. Clutch Vibration
  7. Turned my car back to stock except for reflash.. will it be an issue?
  8. Mototune break-in... is it too late?
  9. shifter
  10. what do u think about this oil cooler
  11. Freak Engine?
  12. break-in with just new block?
  13. New Clutch for 06-Z need HELP!!
  14. transmission warranty ?
  15. Powerhouse Amuse isn't wasting time
  16. Which aftermarket LSD?
  17. question about changing pumpkin and going turb
  18. air/fuel help?
  19. belts incl w/ur crank pulley too big
  20. 03 Power steering flush
  21. InGalls Engine Torque Damper "The Stiffy"
  22. Painting piping black?
  23. Can you overheat AT with autostick?
  24. 2007 Oil Change
  25. Oil Change - oil well over full?
  26. car problems please look?
  27. Need members help, Taking Nissan to court re oil consumption
  28. Oil Pressure Gauge still going crazy!
  29. Rough idle
  30. Before and after bolt-ons dyno!
  31. 06 vs 04/05 350z Engines
  32. Custom turbo manifold?
  33. Clutch/transmission Noises
  34. High RPM shifting and the clutch
  35. nismo flywheel = problems?
  36. 07 Reving Problems?
  37. rb26dett and awd swap into 350z
  38. ngk laser platinum?
  39. How easy is it to get to 320whp NA?
  40. Clutch click on release of pedal
  41. Did I damage my clutch? Burning smell
  42. Transmission Warranty Dispute!!!
  43. What should I do for a LSD SWAP
  44. forced induction or all motor?????????
  45. Will the 350z Greddy Emanage work 4 other cars?
  46. 04 Non LSD to 06 LSD Swap
  47. Pennzoil Synchromesh
  48. Anyone use a pre-oiler?
  49. engine dampener brace with turbo
  50. Any news on the AT tranny geting built
  51. Noises are driving me crazy!
  52. engine stalled while driving (base 6spd)
  53. Short Nismo clutch review(sorta)
  54. AAM Hiring - Sales, Service, Marketing, Account Manager!
  55. Z1 Motorsports clutch and ultra light flywheel
  56. Engine pre-oiler
  57. wrong bolt??? AAM spacer PICS.
  58. constant burning clutch smell(not cuz i dont know how to drive), need advice
  59. ISO Thermal Spacer made out of?
  60. Engine Ticking Noise
  61. 03 Z - Error codes p0300 and p0021
  62. what is my problem here?? Pls.dont move
  63. Notchy tranny?
  64. Do we have a factory oil cooler??
  65. Need help concerning Cooper TB heater
  66. Rev-up intake question
  67. What Diff oil for Cusco RS LSD?
  68. Front Mount CAI
  69. Engine turned off !! urgent help
  70. 350z hp sticky thread?
  71. what happened here??
  72. 1800 hp VQ, step aside 2jz
  73. Battery Problem?
  74. Vh?
  75. Plenum spacer causing oil loss??
  76. 06 Non-revup
  77. New sticky clutch issue
  78. Bad valve cover gaskets...?
  79. Humming on the drivetrain, please help!
  80. Where can i buy underbody braces?
  81. Tach jitters
  82. Odd problem. Brake and Battery light staying on.
  83. Re: 2006 350Z Engine Recall
  84. Quaife LSD: Should I get it with the way I drive?
  85. Thanks Motul 90PA Differential Oil!!!
  86. Do any Pulleys not cause oil leaks?
  87. Manual Tranny drain size?!?
  88. '07 VQ35HR - Still consuming oil?
  89. ring gear size of the 350z??
  90. aftermarket sequential transmission set-up for auto z question
  91. KJR Crank Pulley owners be careful
  92. Horsepower question...
  93. Suggestion for new clutch
  94. Tranny flush
  95. How hot is the engine bay?
  96. loud screeching engine noise... HELP!
  97. service engine
  98. 93 Octane?
  99. is it normal...
  100. LWFlywheel=Crank walk?
