- Swapping engines?
- All motor build?
- SGP Pivot Ball??????
- 5AT won't switch into manual mode
- second transmission can i get a warranty??
- Where to find multi-chamber tubing?
- Nismo finned differential
- Fuel System Cleaner and Oil type to use??
- had to FLOOR it
- is this the right jwt clutch combo i need?
- washer under guideplate(6mts)
- Valve Body? What year did the 5at transmissions change?
- where can i get a RE short shifter
- Slipping clutch?
- Review on new long block.
- clutch won't dissengage
- any difference in the MAF on the revup engines?
- clutch line install: need help asap pls!
- Just dyno'd my modded 06' rev-up
- What does the injector housing look like?
- short throw in 350z?
- Ok time for action
- Im another oil consumption victim
- Stock LSD
- Oil additives: If and when???
- sport shift.... no worky?
- Rev-up engine
- Opinion on Eneos oil
- AT to 6sp swap anyone interested???
- 03 Engine block competible with the RevUp Engine block?
- Mrev with my mods....
- 6-puck hard on the tranny?
- Heating Issue
- Spark Plugs
- Do i need a new clutch with new flywheel?...
- Base model going with an LSD...
- Apexi Neo issue
- Where are the "total NA package" info
- FD swap question - Jeebus would want you to help me
- 3.9 final drive install question
- so has anyone tried the GTM cams?
- Clutch died, HELP!
- just dyno'd my stock z not too happy with results
- Clutchmasters Stage 4 clutch/lightweight flywheel
- APS STB + ARC box, will it fit?
- Sluggish performance around corners (AT)
- Need pic of injector housing (diagnose ticking sound)
- Going NA, and I need parts with the highest HP and TQ #'s
- Spark Plugs and Wires!!!!!
- Really loud Kaaz LSD
- Can a 5AT be put in Neutral with Valve Body Out?
- Tilton Full Street- Where to Buy?
- Clutch?
- What mod has the most bang for the buck?
- Hey what does stroking mean?
- Where can I buy this engine cover?
- I need some advice on my idle
- Decision... JWT clutch/flywheel or ....
- 350Z pumpkin swap?
- Crossmember replacement
- dynoed my car
- My own Engine Grounding Kit!
- New Stillen Short Shifter Review
- Any Dyno Dynamics Dynos in the DC area?
- service engine light comes on in cold weather
- 07 350z performance modding
- More burning oil questions...
- NA guys...anyone built your heads?? How much power are you seeing?
- Does this actually work?
- how do you tell from a 3.9 gears from a 3.5 gears
- MSD Dashhawk?
- What should A/F be at idle and WOT
- tranny swap
- new engine
- What is the difference between a short and long block engine
- Suppose I have a short block engine built for my Z
- Finding odd size automotive bolts
- cheapest place to get stub shafts??
- First 1K with new transmision. RESULTS
- Need Help with EVAP Relocation
- What the hell... my engine died?
- Does this sound like a Clutch problem?
- 3.91 gear????
- Has anyone had to upgrade the alternator for lots of mods
- ??? where to buy spark plugs ???
- 03 Stock Clutch hard to press down - How to lighten the pedal?
- Tires aren't catching from 1st to 2nd at all.. stupid question?
- Oil Psi?
- Nismo Cams Timing Chart
- JDM Z has OEM grounding kit?
- Purolator PureOne PL14610 Filter revised
- Clutch Kit
- Fuel Injectors
- Crankshaft Position TC, + Resetting ECU
- Does this happen to your Z??
- best LSD for an 06Base
- engine rebuild kits
- port and polish heads
- hydraulics related to gear notchiness?
- Wheel bearings anyone?
