- help please asap
- 350z Grounding?
- Normal oil consumption
- Break-in - how to do it right!
- My 2006 broke down on 1/1
- 3.3 -> 3.5 Pumpkin Swap Question
- Newbie Diff Question
- 3.9 final drive worth it with basic bolts ons?
- 05/06 Rev-up Oil consumption Registry
- ap stainless clutch line
- 07 350z engine spec
- Oh boy, water in engine?
- Purchased jwt clutch/flywheel..
- Rattling Sound when you turn off ignition
- Strange problem - too much play in driveline?
- 6MT question
- FI vs. Built Motor
- Removing Mocal sandwich plate? HELP PLZ!
- AAM Oil Pan Spacer . . . need the directions
- Greddy Sandwhich Plate
- Anyone with experience with these clutches?
- Need Motor Pix
- Problem with my 5AT...
- Blown clutch
- Alternitive to return fuel system..
- Greddy oil pan and GT Spec lower front brace?
- BuiltZmotors review and build feedback
- A few differential question?
- Engine cover
- VQ in its infancy ??
- Info for all modders
- Trans. part number?
- SCC Dec 06 LSD shoot-out ? ? ?
- Top Secret Parts
- 750cc injectors... now what?
- Turbocharge/Supercharge/Popcharger
- Idling
- vq35de block
- Big difference in price here????
- Heard of a company called Uprev????
- Finally--the complete fix for B&M shifter rattle
- oil filters
- AN fittings sizes?
- Stereo effecting the way the car runs??
- Nismo cams advance or retard
- First mod list
- Clutch and flywheel replaced at 16k...
- wat size belt for underdrive pulley
- clutch line
- Good and bad of upgraded final drive?
- Built Z Motors review..
- Whinning noise at 85mph
- clutchmaster fx300 - experience
- Looking for Pic of . . .
- custom pulley setup!!
- Need help: Can't get into 5th gear properly & the whole neighborhood can hear me
- Advice Needed: The whole neighborhood can hear me : Nismo Clutch
- 5AT rear diff for 6MT
- WTF is this ????
- Cracked Radiator
- Concerned about my transmission.
- Almost 0 oil psi under load...yay
- Extrude Hone
- first mods?? is this a good idea.
- Looking to add just a bit more power....
- Need some parts
- manual transmission noise
- Car won't start when engine is warm.
- NA mods
- After market dash
- Yay! Installed JWT clutch myself…
- Neutrailsation of Vmax restrictions
- number of splines in stub shafts??
- 3.9 Gears Help?
- ***05+ pathfinder differential to 350z Q***
- Nismo Clutch contents
- 3.917 gear with F/I
- Engine sleeving options...
- Intensepower and Motordyne
- How much rwhp will stock differential hold?
- Windshield washer resivoir
- Tranny Need Help ASAP....
- Short block question.
- Rogue Short Shifter problem...Help please
- Anyone running E85?
- How would my Modded AT perform against a stock 6 speed?
- stillen ED void warranty??
- stillen engine damper
- B&M Short Shifter Q
- Nitrous and Procharger
- ACT or RPS
- "Intense" joke
- Questions about Engine Swap and AWD Setup
- Getting a clutch - possibly ORC clutch
- Help with jack stand
- UR pulley squealing - should I just switch back to stock?
- Question, cruise control gas consumption
- Which LSD is good?
- Stillen flywheel????
- hey what determines how much an engine can rev to?
