- Clutch MIGHTY SOFT!? what gives??
- 1 piece driveshaft???
- which catch cans have a filter or air/oil separator inside?
- OK to use 80W90 in Transmission?
- Problems With My Edge Racing Torque Converter
- My A/F is F'ed!
- Changes from year to year
- Engine Identification! HELP PLZ?
- differential question
- NEW PRODUCT: AAM Fuel Return System - Basic!
- I'm going to get my arse kicked for this one....
- Lsd
- When is someone going to start rebuilding trannies
- Spacer or new plenum?
- clutch sliping ??
- 5AT Shifting in MM mode
- Brain Crower Camshafts
- difference in 03 differential and 06 differential
- Oil Change
- Odd Question, Engine VIN / Serial #?
- does removing the AC remove the heater too?
- Will an '04 LSD pumpkin fit an '03
- Nismo LSD manual help
- Coil-Pack going bad?
- Buddy Club racing condenser
- 350z Tech help please?!
- N/A reliability
- HELP>>Is this clutch any good??
- clutch and flywheel...
- Trans fluid
- Darton sleeved 3.8L vs GTM stroker 3.8L
- Tranny and warranty question
- What is a "double clutch."
- Auto Swap?
- Engine damage pictures.
- Samco Induction hose.
- AASCO Flywheel? Need Info Please.
- Just installed new tranny, WTF!
- rpm signal
- How Much Is A Brand New Engine PLEASE HELP
- Spark plug spacing
- strut bar
- Best synthetic oil type...
- idle problems
- Pics of engine out and tranny still in place please!
- rear cooling?
- Help!!! OIL PRESSURE 130 PSI?????
- Sharif at Forged is awesome!
- Feeler: Base Pumpkin
- 03 Z possible problem
- platinum vs iridium spark plugs
- How do I adjust the fan's "turn on" temp
- What to buy
- P1284
- help with gas analysis
- cvts????????
- Will a '06 pumpkin fit in an '03?
- Underdrive Pulley Belt HELP
- Aftermarket LSD's and you:
- 600whp 350z
- Replacing rod bearings while engine still in car?
- How can I tell for sure if the diff is LSD or open?
- Synthetic Oil Issue..a big deal
- Best Short Block build for the $$$?
- VQ40DE revability
- oil temp sending unit mounting?
- Need suggestions for 2007 Mods
- What next
- Stock upper plenums bolts/screws
- Engine Blew Up Please Help
- Timing Belt???
- Transmission Rebuild?
- *E-manage Ultimate Tuned* Pics and Dynos Inside
- Would a damaged evap canister throw CEL?
- how to swap pumpkins
- Clutch Pedal stickin?? Yr. of car ???
- ahh! so tempted
- new clutch time?
- new skyline motor swap into 350z
- Help! ECU removal on '06's...
- Aftermarket Clutch Install at Dealer? Yes or No?
- +25whp?
- Uh-oh.. wierd sound at startup..
- quick final drive swap help
- Aftermarket Clutch Question
- jwt new clutch smell?????????
- Rod bearing!
- 3.9 Final drive question
- Going Synthetic...
- RPM at 1500k at startup normal?
- 06 auto hesitation problem!
- check engine light help...
- Check Engine Light After Cams Install
- Removing AC line
- 2006 camshaft questions...
- Question about oil temp sending units
- Rear pumpkin/differential help
- Royal Purple tranny oil?
- Help - looking for clutch and neutral position wire
- Need more power!
