View Full Version : Engine & Drivetrain
  1. Odd noise when clutch is released
  2. 350z rb20dett?
  3. What upgrade should I do?
  4. WEAPON R Torque Damper
  5. breaking in the new tranny - take a look please.
  6. Race Gas, NA?
  7. How many RPMs should the engine idle at?
  8. Are there any benefits switching to semi-synthetic
  9. pulley question, please heplme
  10. 3rd gear grind - what tranny to put in?
  11. I need new tranny and I want 3.917 gearing
  12. CM clutch and flywheel...whos got it?
  13. Raised compression....
  14. 350Z smokes when WOT
  15. Automatic
  16. Put diesel fuel injector cleaner in 350
  17. Who offers CF Radiator Shroud
  18. Calling N/A Cars with TUNING or REFLASH and DATALOGS
  19. Did i use the wrong Tranny fluid???
  20. Near Stock 350Z & G35 Needed!
  21. does my LSD not work?
  22. Engine Dampner?
  23. Transmission?
  24. Tranny boot part number.
  25. show AND go
  26. Stupid Drive By Wire Throttle Bodies...Need to rev motor...
  27. Anyone else had damaged u-joints in driveshaft??
  28. 2JZ Motor In 350z..
  29. Built NA motor w/ Water/Alcohol sprayer
  30. anyone witha nismo lsd installed in SoCal???
  31. Would this work?
  32. VQ35HR pixz
  33. Burnt out Throw-out Bearing
  34. Quaife LSD
  35. 1.5 or 2 way
  36. Aftermarket LSD Information...1.5 or 2 Way
  37. Uhoh I think i got axle clicking
  38. Final Drive Gear - 3.5 vs 3.9
  39. Dyno'ed my Stock 2004 350z...244.1hp/235.8tq
  40. B&M Rough Shifts
  41. Picture of shatterd piston. Crappy dealer service too.
  42. NA and higher octane.....
  43. Whats the cheapest way to get my 0-60 to 5.0 Flat?
  44. Malfunction Indicator Lamp(MIL)
  45. New clutch disk, old everything else...
  46. Replacing Tilton for ATS
  47. ATS Carbon LSD into auto G35 open diff?
  48. Deatshwerks Injectors
  49. Tips, Suggestions, Advice, Experience on installing Clutch..
  50. Cost of engine/tranny swap compared to tt uninstall + install?
  51. AAM Fuel Return System!
  52. What is the stock injector size for the Z?
  53. 03' Hard Clutch can anyone help?
  54. Power steering fluid getting onto the alternator
  55. Need Advice...Oil Filter
  56. aftermarket LSD on Base model
  57. First time Engine Startup
  58. Tomei 268 v. Nismo Spec 2
  59. Interesting Twist on bad tranny issue...
  60. Need help storing my engine...
  61. Spark Plugs
  62. Questions on tranny swap At to 6sp HELP NEEDED!!!!!!!
  63. Vid of my weird JWT clutch.
  64. Anyone Running Methanol Injection
  65. some comments, please......
  66. Need Insight!
  67. Help with cam position sensor
  68. Clutcher
  69. Any tuning shop offering modification packages with advertised results?
  70. Adding power without voiding my warranty
  71. vibration as rpm reaches 3000 rpm
  72. 03' AT trans Questions
  73. New VB yey!
  74. How Can I Tell....
  75. maintenance on cusco LSD
  76. stroker feedback
  77. Adjustable FPR?????
  78. heads for rebuild opinions welcomed
  79. Stock Flywheel
  80. AT/MT swap
  81. ARC Oil Cooler just ordered!
  82. flywheel?
  83. Price for replacing A/T?
  84. Your car plans
  85. 5th Gear Grind
  86. flywheels & girls
  87. 6000 miles, droped a valve.
  88. Auto transmission fluid
  89. Just ordered the JWT Clutch/JWT Flywheel and JWT Pop Charger
  90. Turbo cam question
  91. Just got car dyno'd
  92. Got lots done to my car and getting results today!
  93. Torgue Converter
  94. VB upgrade
  95. differential question
  96. How to clean the Throttle Body...
  97. Just FYI; It's important to have the ECU mounted properly!
  98. UR crank pulley belt problem - Part#
  99. Dyno graph for 06 stock Z!!!!
  100. super afcII memory
