View Full Version : Engine & Drivetrain
  1. How many miles can the VQ35DE go without needing a rebuild?
  2. My Z track will not let me turn on VDC
  3. Pulley Question
  4. A New Addition to the Forged Team
  5. Accidently reved redline while rolling
  6. Valve ping on 06
  7. 06 Nissan oil problems
  8. loud gears
  9. Clutch line
  10. Replaced built engine with used stock one...warranty question
  11. Gas Octane Level Usage
  12. Will a Turbo System Make Give my Z better Gas Mileage?
  13. ( at ) trans install
  14. Just ordered a few parts
  15. Time to dyno?
  16. Rear Axle Clicking
  17. New Valve Body
  18. upgraded axles anybody?
  19. Oil consumption, worries, etc.
  20. HKS Twin DLI install instructions?
  21. ATS and 3.9 Final Drive
  22. Clutch & Flywheels...Its All Greek To Me!?!
  23. Clutch question...
  24. ACT prolite and CM FX300 install
  25. Burning oil??
  26. trans probs
  27. gaining more power of a stock Z
  28. Tranny fluid
  29. Z uses same piston rings as used in 2.5 engine?
  30. Those that know about this trans and clutch come in.
  31. $2,000 for now... what to spend it on?
  32. 2006 o2 sensors
  33. Clutch won't pop out, Can't Drive
  34. 06 Motor swap ?
  35. ECU Error Codes -- very helpful
  36. Poll for all 06's owners
  37. The new VQ35HR
  38. Trans. exchange{009}.
  39. Car won't start sometimes.
  40. If anyone hasn't changed the differential fluid yet...
  41. Installed Braille Battery. Bose Stereo not working...
  42. Using copper NGK plugs to resolve pinging.
  43. Price of auto tranny fluid change at dealership
  44. leakdown test, how long should that take?
  45. Any one ever had a bad PCV Valve on there Z
  46. SPEC CLUTCH problem
  47. Question on engine compatibility
  48. What to do after cracking a head?!
  49. need some opinions on my 5AT
  50. What should I to start with before FI?
  51. Startup
  52. Two engine dampers in Z
  53. Power steering fluid
  54. Question about rev-up
  55. Removing diff pumpkin
  56. Diff. cooler?
  57. Fuel pump question
  58. Supra 2jz-gte swap into 350z??????
  59. Pheonix 5AT Racing Valve Body for RE5R05A
  60. New owner, need advise with service issue
  61. Dont you just love it when people help you out!
  62. cams advance timing?
  63. Cams and nitrous. please look
  64. says I had a Cylinder Misfire...HELP
  65. Block with bent rod...still good for building?
  66. ATS Carbon LSD
  67. Forged Pistons And Rods
  68. Performance Motorsport's Pro Series Heads Now Available
  69. My Progress with Cipher (charts included)
  70. 2006 350z redline?
  71. New tranny.... Bogging?!?!
  72. Just dynoed my car
  73. How much does the pumpkin weigh?
  74. Got Dyno'd Today....
  75. I might have killed the car.....
  76. Dealership actually doing Right Thing...
  77. Car shudders/chatter when engaging in 1st
  78. 6spd swap?
  79. Weird clutch problem you might not have heard of.. HELP!
  80. Anyone with a 3.9 gears and cams?
  81. time for a new clutch
  82. Honking sound while shifting @ high revs ??
  83. building a n/a monster
  84. Dampners and reducing harmonics...
  85. Stillen Stage4 Plus Exedy Clutch & Flywheel Install Pics
  86. Grinding Noise
  87. ppl with AUTO Q?
  88. Greddy Informeter?
  89. fastest place to get a jwt clutch
  90. do clutches come with warrantee?
  91. Feeler for GB
  92. clutch suggestions?
  93. rought idle
  94. Ahh.. problem! Something sounds like its dragging..
  95. Need quick help!
  96. Question about manual transmissions(newbie here)
  97. Clutch Noise?
  98. idle problem ??!!
  99. Aftermarket Speedometer and Tach?
  100. Need Install Guide to SUN Hyper Force System
