- Who Needs an HKS DLI????
- High oil useage with synthetics
- Car would not start.
- Cipher V1.03 Update
- Fuel sending unit ?s
- Greddy Radiator for 350Z
- line lock question?
- So far..
- What Oil Pan baffles do you think are the most affective?
- feedback wanted!.. car eating alot of oil... salvage title 350Z
- Possible full tranny upgrade for 5AT users...
- NEW! Project Kics Drain Bolts!
- Waiting for clicking noise rear axle parts?
- Opinions/ poll! vote
- Out of Curiosity
- To Underdrive Or Not To Underdrive....
- should i pay to get kjr pulley installed
- 3rd gear problem, need input on what the dealerships have told YOU.
- Convert stock thermostat to Nismo?
- Tranny & diff fluid swap: did I do something wrong???
- Would Nissans CVT Tranny have any advantages over the 5AT?
- HELP! Nismo Thermostat Install
- New Owner, Motor drivetrain questions
- Ok Guys- here's a good one for you. CEL light
- What is the best way to fix this.....
- Broken pistons from tracking
- rb26 350z .???
- Low 12's high 11's?
- At5
- Why is Nismo LSD not for highway?
- Car won't crank
- SGP Valve Body
- Water only in cooling system?
- Any stores carry Redline oils or does it have to be ordered?
- help! did something stupid
- 350z rear wheel bearings, same as g35's ?
- need 2 bearings for differential.
- Cusco Type RS Differential setup help...
- Just wondering what if....
- anyone ever use this coolant?
- Aftermarket Auto Tranny
- Now im getting really mad
- Zeitronix Wiring
- Another tranny swap thread
- I need true Z mechanics on this one
- kinetix v+ plenum
- skyline motor in a 350z
- short throw
- Need Clutch Advice for NA; What will stand up to the Abuse?
- Need some help?
- Removing stock oil cooler
- Torque Specs for the Pumpkin's bolts?
- CHanging radiator hoses this weekend.....
- Near Catastrophic Engine Failure
- Nissan Tech please...
- conversion
- Installing flywheel???
- trans / clutch problem...
- Final Drive and Power gains
- does anyone rev over 7,200rpm on here?
- Well thought I was running lean but...
- my clutch...
- fuel locking clip
- OK. This is kinda Wierd...
- High pitched Clicks as I disengage clutch
- aluminum drive shaft
- 11 second 350z, newb.
- Tech Z DIY
- How would you run in a new strengtened engine?
- Very Delayed Oil Change...
- Alternative to FI
- 3.9 FD or Nitrous? please help!
- Issue w/ cam install
- Need compression test #'s for those with aftermarket cams
- How much horse from the stroker?
- duration or lift when choosing Cam's
- Info on VRT
- Still dont have my car: help guys!!!
- Unorthodox Pulleys
- Where are you crawford???
- Want to keep my Z NA??
- Pictures of DE Type 1 on a 350?
- Does any US Z model have cooling ducts on the diff? *PIC*
- Tomei LSD...anyone know anything about it?
- Clutch Pedal Free Play: Can a tech explain?!?
- Little help please..
- burning oil
- Cam Sensors
- VQ35 and "other" engine
- 4.3 stroker kit?
- Cusco Twin Plate Carbon Clutch! *picts*
- VB Upgrade... Forged Internals or SPG?
- MY AT TT Z with 3.5 FD my review
- Requesting for reputable experienced installer for Crawford headers San Diego or LA
- shifter
- The Oil & Power Steering Cooler Thread
- a Noob question.
- please help me!!!
- Comments on clutch pedal feel with ACT, Spec, and RPS...
- problem please help :(
