View Full Version : Engine & Drivetrain
  1. Freaking Pissed
  2. 3.9 final drive gears..
  3. 6th gear on local street?
  4. Does anyone know if these products work the way they say they do?
  5. Where to find Nissan engine hoist slingers
  6. Stillen Oil Pan Spacer
  7. Pumpkin swap tomorrow...
  8. Transmission oddity
  9. Changing Differential Fluild - additive
  10. Turbonator question!
  11. Tachometer signal wire
  12. Convert a 05 287 engine to a rev up?
  13. New To This Fair Lady
  14. Question? ACT 6 puck clutch kit
  15. Driveline Power Loss -how much?
  16. Cusco or Nismo???
  17. Power steering cooler
  18. Going all out.
  19. Cheapest Place to get Ferrea Parts
  20. PLS Help My Engine Problem
  21. Auto Tranny question.
  22. Some Cylinders Running Lean?
  23. Dyno #`s for several cars and an 03`Z with a couple mods.
  24. Jwt Tb
  25. Tranny Noise
  26. fluid dampner?
  27. Underdrive Pulleys?
  28. Post your used oil analysis!
  29. radiator dimensions
  30. Clip: Engine Bay
  31. 6th to 5th Grind
  32. to all diy guys
  33. chasis dynos for stock 350Z?
  34. 3.9 final drive top speed
  35. New Mods, wanna guess the new WHP?
  36. plx r-500 on the way
  37. HELP, how to Change spark plugs?
  38. Gears dont want to go in...
  39. Rear Cylinder Coolant Bypass Modification
  40. FYI, HKS DLI II - worth every penny NA!
  41. Kudos to Mossy Performance!
  42. S-mode in auto?
  43. AWD 350Z(No more shift drifts)
  44. Cooldown with Stock fans
  45. Biggest Off the Shelf cams avail?
  46. Car will only idle
  47. New tranny and problems getting into gear from a stop
  48. Clutch/Flywheel Combo for TN kit
  49. Looking for a 6MT rear
  50. New Owner
  51. Tranny blew on my way to DynoComp
  52. clutch chatter fixed with new drive belts
  53. RPM at startup
  54. Got my UOA!
  55. Nismo clutch & fly wheel
  56. NISMO GT LSD Not Working Right ?
  57. pulley install
  58. what mod next?
  59. Question for the 5AT experts
  60. 350Z UR Pulley on an FX35?
  61. need the size of the OEM crank pulley (urgent!!)
  62. For those with a radiator breather tank
  63. Fully built/sleeved VQ pics..
  64. What 3.9 final drive gears to go for?
  65. Coolant change questions
  66. Everyone, I will be in PHOENIX next weekend...
  67. Idle and Misfire problem
  68. Engine Install
  69. Oil Cooler. N/A Benefit?
  70. looking to get the timing cover on the engine chromed or polished...
  71. Driving with one stock header and one aftermarket??
  72. VENDORS WHICH ONE HAVE CoreCharge Pro-Torque Converter
  73. Question about aggressive cams for NA?
  74. Lossing oil presure?
  75. Hose Size In Mm?
  76. Electric Fans
  77. RPM needle stuck
  78. Press Release: Exciting news from Forged!
  79. Need help finding the right tool........
  80. SGP VB -turnaround time
  81. Any Ideas for more power
  82. ok need fully built motor
  83. Finally Cosworth Heads!
  84. Final Drive and Gas Mileage
  85. Which Clutch/Flywheel set-up is better: Tilton or JWT
  86. Did almost every N/A mod for $2000
  87. Some new dyno numbers!
  88. CALLING ALL VENDORS! Where to buy HKS DLI and HKS intake?
  89. Too many Options
  90. Will you trow a CEL and lose cruise control by going from 3.5 to 3.3 gears?
  91. Removable Navi face
  92. Installed Sun Auto. HyperForce and MRev2 this weekend...
  93. WATs wrOng wit My car?? OVERheating?
  94. Basic Bolt ons
  95. Adding an oil cooler ?
  96. engine gurgles and misfires after changing sparkplugs
  97. I think I found my marble in the can engine problem.
  98. Clutch slave gone bad?????
  99. Can't go past 2k RPM, what gives?
  100. Iridium Plug Benefits?
