- 17 air/fuel ?
- Is Direct Injection a Good Idea?
- Where to buy JWT flywheel...
- How hard is it to install your own clutch?
- A2R (Ebay) Engine Torque Dampner Impressions
- G35c 5AT, need LSD! need suggestion!
- Flushes on coolant, clutch, power steering and brakes fluids *?*
- Liquid on test pipe
- Manual--Shifter Free Play while in Gear-please post a response
- Another Clutch Slipping...question though..
- Choices for Titanium Valves?
- Very simple oil catch can
- Tranny work at 55k mi?
- info needed: diff / tranny fluid change
- Parts needed for higher Hp?
- weird noise after JWT clutch/fw install
- 5th gear engages 3rd; Cant find 5th
- HELP!!!!! part 2!
- Help!!!!!!!!!!!!!!!!!help!!!!
- Reset ECU With Neg. Battery Terminal and BRAKE PEDAL?
- new tranny = noise and power loss
- Please Help!!!!!!
- Anyone got a DIY on a fuel return system install
- Looking for Lifters...
- Competition Clutches?
- clutch adjustment?
- Qualife LSD on a 5AT
- Upgraded fuel pump
- Has anyone datalogged timing?...show your graphs
- help.. what else do i need for clutch installation
- question
- central20 final drive gears?
- Please help...antifreeze
- Cusco RS LSD shipped lock-up setting?
- RUSTED SPARK PLUGS! I know this is gonna hurt!
- Question about radiator panels???
- Any other places for ATS carbon clutches..?
- Overfilling The Manual Transmission
- Nismo LSD come with Stub Axles?
- Help!!!Installed JWT clutch/flywheel now car won't crank!!!??!
- Anyone heard of Dastek Dynamometers?
- ACT Clutch/PP opinions
- Fidanza flywheel?
- Valve tranny upgrade?!!
- Cipher Logs, need your inputs to decipher my problems!
- Questions: pumpkins
- Looking to buy
- What's the deal with pulleys?
- Quick Fuel Question
- oil change and brand
- ZEETOYZ + KINETIX=Lots of Bling!!
- Torque wrenchs
- check engine light showing misfire code # 302 please help
- My AFRs on bank 1 versus 2 are way off
- Swapping an 04 G35 engine into an 03 350Z
- Has any one seen this
- Stroker Kits...?
- $1000
- Central 20 Gears Installed...!!!!
- more aggressive gears
- jwt clutch and flywheel, and crank pulley
- Instructions on replacing thermastat?
- JWT/Fidanza flywheel installed--Impressions
- LEVEL 5 Axles!!!!
- stock block demensions
- Need help on the Error Codes... Cam sensor problems?
- Potential problem with stock fuel system.
- AEBS Stroker Kit
- High Revs at Startup
- Jwt Combo Clutch INSTALLED
- How about this idea...
- Tilton Clutch and Flywheel Review
- Stillen Oil Cooler
- B&M Short Shifter....
- 3rd gear/Tranny Warranty Question.. HELP!
- Performance Main and Rod bearings ?
- Liquid Cosworth motor oil?
- speed limiter
- Anyone have experience with Sun Auto hyper voltage system?
- Help with grounding kit install
- Transmission/Clutch Replacement (Warranty)
- What's that noise?! Broken throttle body???
- jwt clutch
- Heater broke after radiator flush
- Swapping a 350z engine in a G35 Coupe Question
- Kinetix?
- Need a new clutch - what do I choose??
- Transmission rebuild question
- Denso Iridium or NGK Iridium
- Clutch, Flywheel, Plenum and Pulley
- went in for a oil change and came out with more!!!!
- Denso Iridium spark plug gapping
- Ultimate Racing VQ35 Heads
- Spark Plug change after reflash question
- New 4th Gen VQ: By Sport Z Mag
- PnP HKS Twin Power DLI II for the Nissan 350Z and Infinity G35
- nismo cams = need new valve springs?
- 2nd Gear on my 6mt question?
- Clutch change question.
- Question on Mod Maintenance...
