View Full Version : Engine & Drivetrain
  1. Looking for 350z engine
  2. SwainTech Coatings, has anyone used it on there NA 350Z?
  3. Oil and Plugs.
  4. Dont know what flywheel n clutch combo to get
  5. When You Reset ECU, What Map Does It Go To?
  6. Engine cooling problem????`
  7. Strange consistent knocking/rattle noise coming from the engine i think.....
  8. my ECU is in 'limp' mode??? help
  9. 5AT Transmission Fluid Change
  10. Cosworth 350Z
  11. Change ShiftPoints on a 5AT ?
  12. Difference b/w the 287 and 300 hp motors
  13. Clutch Install - San Diego
  14. Gauge set-up Pictures?
  15. 350Z FInal Drive = R200V correct?
  16. From AT to manual
  17. My JWT Clutch feels like stock after break in
  18. LSD rear end DIY
  19. AC pro's and con's
  20. Camshafts
  21. What Performance Parts do you guys want????
  22. (03) 287hp HEADS Compared to (06) 300hp HEADS any Difference??
  23. build or not to build
  24. Rev Up Motor Mod List. 350z
  25. Jwt Flywheel
  26. WTF???... heater doesn't work and the car was over heated...
  27. Get the air out of the coolingsystem
  28. G-Techpro, Passport G-Timer, or Beltronics Vector FX2
  29. Stillen Valve Body upgrade for FI 5AT...worth it???
  30. E-manage Ultimate: what all do I need to buy?
  31. Check engine code p1283????
  32. Tuner VW, Tuner Bosch, Tuner pro VW, tuner pro bosch????
  33. New Top Secret Parts
  34. ATS lsd
  35. Problem with KJR pulley
  36. Should I be worried?
  37. Diff fluid recommendations, and a question about capacity..
  38. MAX POWER STD GEARBOX and DIFF WILL HANDLE ????
  39. Need help with clutch selection!
  40. man. i bit the bullet.
  41. Need A 350Z Input Shaft
  42. size of hole in upper plenum for throttle body
  43. Turbonetics TS-1 Motor Oil
  44. Clutch & Fywheel
  45. Question concerning my built NA heads!(Richie, Nathan?)
  46. ECU Reflash to Avoid SES?
  47. Do you burn oil? Describe your driving habits...
  48. Central 20 3.9 Final Drive question
  49. 2003 or 2004 350z modding
  50. JWT parts integraded with stock?..JWTcams/OEMvalves...
  51. 06.. wont reset ecu
  52. questions about the Guaife ATB LSD
  53. Oil leak
  54. what is "reflash"?
  55. i get a new motor!! (maybe lol)
  56. 3rd Engine, still burning oil... How long does it take to seat the rings.
  57. Crank pulley ?
  58. bent valves, and damaged sprocket...somthing. replacement options
  59. UR Pulley Tension (?)
  60. Do more aggressive camshafts change exhaust tone?
  61. Nismo Oil Cooler Question
  62. 3.9 final drive Gears
  63. Car running lean...
  64. Tilton 16lb clutch/fly kit
  65. engine has been pulled... what upgrades would be best while it's out..headers/clutch/
  66. Is it really worth the swap and what terms do you guys consider fair in a sponsor.
  67. Detailed diagram of VQ35 heads/components?
  68. VQ35 T56 Conversion Help
  69. Suspension member what?
  70. Please, is this NORMAL???
  71. there aren't any better AC belts than stock nissan belts are there?
  72. Setting motor to TDC without chain?
  73. Walbro...FPR needed??
  74. Clutch pressure build up after driving.....
  75. pics w/ aftermarket radiator?
  76. Clutch and Flywheel Questions
  77. Warranty For New Gearbox/clutch
  78. crank key
  79. Resetting the ECU did something!
  80. Clutch fluid boiling?
  81. Stock '04 G35C (5AT) Dyno @ Advanced Motor Sports
  82. 3rd gear grinds?!?!
  83. Dyno reads very lean on stock Z
  84. Alternator pulley nut size???
  85. Quick Clutch Question
  86. Z1 valvebody
  87. timing cover
  88. Ur pulley kit difference
  89. Quik ?-Z comes from the factory with what motor oil?
  90. mods!
  91. Nizpro Australia N/A build-up
  92. 2004.5 idle
  93. Question for JWT clutch/flywheel combo owners
  94. Short or Long
  95. Shippin An Engine??
  96. Performance Clutch Recommendations?
  97. DNX Exhaust
  98. AAM return fuel system
  99. Anyone run Defi A/F gauge?
  100. Cipher Diagnostic System - New Vehicle Application Update!
