View Full Version : Engine & Drivetrain
  1. Blowing Coils... Accept ECM is goner or?
  2. bleeding clutch and cracked... something
  3. resurfacing act flywheel?
  4. Battery
  5. Changing the Final Drive Gear
  6. CD009 in need of repair (synchronizer)
  7. Stock Clutch + Aftermarket Flywheel?
  8. Power steering pump output?
  9. Problems at a stop
  10. 07 HR won't go into gear
  11. Bad performence after 4-5k RPM
  12. ACT clutch/flywheel problem
  13. Outcome Predictions needed (HR Cams)
  14. aftermarket oil pressure sending unit?
  15. plz, who can help me?????
  16. Rekeying
  17. Cheap 4.083 gears
  18. APS oil pan and Fumoto drain Valve
  19. Idle air control valve
  20. Won't pass smog! Please help a z out!
  21. speedo gearing?
  22. PAS Cooler
  23. Anyone see this months modified mag?
  24. Transmission: CD000 to CD009 - Problem!
  25. clutch question
  26. what are stock internals worth?
  27. p0132 & p0152 codes, rough idle when cold
  28. New clutch is too big?
  29. clutch kit and flywheel
  30. Performance Tranny Mount, my Options?
  31. Clutch pulsing - ACT flywheel and Clutchmasters clutch
  32. vlsd torq specs and drive axle install
  33. OS Giken Gear Set
  34. valve spring rev limits
  35. Help, Wheel Spin at 80 MPH?
  36. Clutch help asap
  37. Solid Transmission Mount on Automatic?
  38. Error Codes P0171, P0301 & P0507. Help please?
  39. Megan Headers question??
  40. Transmission Grinding
  41. valve adjustment with new cams??
  42. Fuel Leak Possibly
  43. may be a newb question
  44. Check Engine Light
  45. Installing AAM Fuel Sensor Adapter
  46. Oil Cooler infront of FMIC?
  47. Need help - "injector connector" for engine harness
  48. hipervoltage kits ????????
  49. Depinning the MAF sensor
  50. clutch pedal sticking slightly
  51. Pinion flange swap??? anyone have spare diff laying around?
  52. can you get higher rear gears? ~3.08?
  53. cold start and alum fly
  54. Anyone with SPL Differential Mount Bushings NOT installed
  55. where is the fuel pump
  56. cant jump start my 2003 track model....
  57. Hard to get into 2nd gear and Grinds when it does
  58. 3.5 for 3.7 HELP ASAP
  59. stiff steering
  60. Starter grinds on start
  61. Throttle control motor relay constantly pulling power
  62. Help Removing the Radiator..
  63. Just got a used LSD
  64. VLSD in Base without new axle
  65. TCM (Transmission Control Module) Part number?
  66. Detailed specs of lower plenum ports & bolt holes?
  67. advice about short block
  68. Help help
  69. AWD 350z
  70. Machine shop rates
  71. Please help me... about TCM and Auto Transmission...
  72. Help - Throw Out Bearing Question - Trans out of car
  73. Resonated TPS, resonator damage?
  74. PCV system vacuum leak
  75. engine cranks wont start / key wont program
  76. What I'm looking for in power...
  77. Teflon fuel lines
  78. Exhaust rasp idea!
  79. Gaskets
  80. Blown Subframe Diff. Bushing
  81. JWT Flywheel installation Question
  82. airflow sensor? help please
  83. trans. swap?
  84. Will 08 tranny fit 04?
  85. APS 3" true dual, to install or not to install?
  86. Automatic transmission filter change....
  87. Injectors: SARD
  88. 2003 transmission problems
  89. Clutch/Trans/FW questions
  90. Wow please help!!
  91. question concerning putting an engine in my car
  92. Another source for 3.9 FD?
  93. 2004 350z Engine Failure
  94. Someone who makes, thermostatic oil sandwich plate, w/ 1/8 ports?
  95. CNT High Flow Cats Feedback?
  96. my clutch died in 45k miles
  97. Help, just had Exedy Stage 1 & JWT flywheel installed…chatter box.
  98. ***reaching out to the clutch guru's***
  99. Power steering loss while passing?
  100. oil consumption...yeah again
