View Full Version : Engine & Drivetrain
  1. Dynamat on Pop Charger Heat Shield
  2. guage wires?
  3. Nismo S2 kit...
  4. better sounding??
  5. Question re: spark plug anti-seize
  6. How-To: Crank Pulley Install
  7. anyone using octane booster? If so which one?
  8. What Clutch do you have and do you like it?
  9. Safe to rev the stock block VQ35DE to 7500 RPM
  10. Removing valve body ?
  11. Big Power Loss!
  12. Dyno'ed 240whp -> 272whp
  13. Clutch and flywheel performance question
  14. Acpt Carbon Drive Shaft
  15. nismo flywheel
  16. What yall think about this.
  17. is a little engine knock normal under load?
  18. royal purple....what kind??
  19. What's it worth?
  20. Help!!! Tranny disengaged!!
  21. Resources for "old z's"?
  22. Review: JWT clutch and flywheel
  23. Battery/Brake Fluid shrouds
  24. HFS : Injection improvement for our Injection Coils
  25. Cams for REVUP motors?
  26. Shift light pictures
  27. best crank pully??
  28. throwout bearing noise?
  29. Anyone have resonated test pipes with HKS True Dual Exhaust?
  30. Voiding Warranty?
  31. UTEC USB Support?
  32. Pesky ECU Issues - Any real solutions yet?
  33. a/f tunning help
  34. Good Read JWT Clutch/Flywheel
  35. Lightened flywheel question/problem
  36. how many turns did u make for your lower engagement mod?
  37. Clutch/Flywheel Home Install Possible?
  38. ALL motor questions...
  39. Under Chassis picture?
  40. Question about exhaust
  41. Installed my new clutch light weight flywheel
  42. Evap Canister Relocation
  43. help!! what is the tq spec for the crank pulley.
  44. Weird noise at 80mph and above
  45. Tightening KJR Pulley on AT
  46. Painting Engine Hoses?
  47. JWT flywheel, stock clutch.
  48. stillen engine tq damper instructions needed
  49. AT 3.5 Pumpkin Swap Reliability
  50. Electrical Grounding Cables - Worth It?
  51. Ts Flash'ed Members Help!!
  52. Nissan truck broken fan belt
  53. more 3.9 FD woes
  54. Dealers for Innovate Wideband?
  55. pro torque converter
  56. Huge dilemma need best possible solutions
  57. UTEC tuner in Texas?
  58. Aam
  59. Naturally Aspirated 350Z Dyno Comparison
  60. How to remove Alt pulley??
  61. Greddy e-manage ultimate
  62. Too bad are cars are so dang hard to get hp!!
  63. Piston question
  64. Apex'i Super Grounding System
  65. Speedhut gauges
  66. Brand new car... tranny bangs when clutch is engaged
  67. Brand new car... tranny bangs when clutch is engaged
  68. Short Shifters....
  69. Someone Please Explaine Resetting The Ecu To Me!!
  70. AWD 350z?
  71. mods you regret, ones that you love
  72. performance motor sport PRO TORQUE CONVERTER
  73. engine dress up kit
  74. visual difference VLSD
  75. ARC differential oil cooler
  76. Pics of engine bays
  77. Crawford Plenum and warrenty
  78. Tick on cold start
  79. Im really confused on what pulley to get!!!!!!!!!!!!
  80. does everyone with cams get a SES light?
  81. Variable Timing Control Ticking?!
  82. dyno numbers and mods
  83. $500 to put into a 350z
  84. what is the differeance between E-manage Blue and the Ultimate
  85. Timing Chain
  86. Poll: Should i sell bolt ons for F/I?
  87. Tranny 008 vs 009 (experts plz chime in)?
  88. Advance Timing on Stock ECU - Dealership says not possible?
  89. JIC Magic Strut Bar + AAM Plenum Spacer
  90. Looking for Tilton Flywheel bolts ASAP
  91. tuning needed after cats+exhaust?
  92. Who has the highest hp/tq for NA auto?
  93. Calculate Anything!!
  94. Anyone Remove Heater heat exchanger?
  95. possible transmission problems
  96. shifting into 5th or 6th gear at high speeds?
  97. Anyone using royal purple?
  98. Utec vs Greddy Emanage vs Greddy Emanage Ulimate
  99. unichip good or fake??
  100. broken pressure plate fingers
