- broken pressure plate fingers
- Tilton Full Street Questions!!
- Unichip on ebay
- any street tuners in or near Orange County, CA?
- Tuning is the key--UTEC's w/ accessories IN STOCK
- WB O2 sensor install
- Reflash or Utec?
- Looking for 6 speed info. Not grinding... yet
- Few UTEC install questions.
- damaged evap canister
- Torque converter and tranny heat
- driveline noise
- Solid Tranny Mount
- FINALLY got my car back from the Dealer but...
- JWT Cams and Nismo VTC???
- just ordered a crank pully do i need it's belt?
- 7100rpm for tracking with stock internal?
- gtech pro ss (used almost new) for $100.00 good deal??
- Just got my tranny replaced but...
- AAM MaxFlow Big Pump Upgrade Press Release!
- tranny probs
- kjr pulley put on today
- clutch adj. '06
- Tranny getting replaced, get new clutch?
- Oem Clutch Flywheel Maintenance?
- REDYNOED MY CAR.. Iam pissed
- Where to get Tomei products?
- Stillen VB upgrade...problem??
- Another UTEC question
- How long does the stock clutch last?
- Any books on AFR/Timing
- How much can I get for a used set of heads?
- Koyo Radiator install on a G35 Auto Sedan...I need some help
- SSV Engine Cover Option.....pics
- Aftermarket Clutch and Flywheel Feel
- How strong are our axles?
- Tilton Semi-Street squeek?
- UTEC Installation Costs
- Need help regarding Wideband AFR Sensors and Gauges.
- looking for clutch recommendations: rps or os giken?
- S/C G35 question about stock clutch
- clutch info
- I cant make up my mind!!!:icon20:
- 06 Z got slower after mods
- Pulley before break-in??
- UTEC Map Switch Installed, what do you guys think?
- ever see oil leaking out of valve cover into spark plugs wells?
- Stupid UTEC question , sorry.
- Royal Purple Specs Needed
- Koyo Rad
- Central Illinois Mods Installer
- no noise
- Need help!!! Tryed to bleed the clutch.....
- AAM Hiring - Senior Technician
- Manual Trans GRINDING
- Altenator Upgrade... Is one available
- D-OHH!! and solutions??
- Measuring AT Tranny fluid level
- clutch flywheel
- Why am I hearing a sloshing liquidy sound??
- Cosworth Motor Oil - Anyone Try?
- Anyone paint their Plenum?
- NEED HELP!! Clutch is Stuck!!!
- ECU reflash
- Short Shifter
- Just Installed KJR Pulley, and just one question...
- Any NA EU users?
- Another UTEC ?: Gains made over reflash
- Kinda worried about JWT cams!
- VLSD question
- is JWT a quality brand? any bad experience?
- E Mgmnt - Dyno Tune necessary??
- UTEC question.. I guess kinda stupid?
- Utec
- JWT valve springs necessary w/ JWT cams?
- transmission 5th&6th
- RPM vs. Oil Pressure questions/ Oiling Mods?
- Just dropped off my car at Scott Performance
- tecnosquare ecu reflash..
- final drive? what is it
- Next Mod Im Lookin Into... Help PLZ
- A girl in distress. Transmission Grind.
- Upgrading the Torque converter on 5AT
- What's a better investment,JWT flywheel or 3.9 gear?
- disappointed dyno numbers.....
- Should I disconnect my battery?
- Engine Whine
- what problems come with the 2003 that can be fixed under warranty?
- LSD & VDC??? Same thing???
- Blitz R-VIT Multi Meter
- clutch not fully disengaged when pedal fully depressed
- engine ticking
- Cams and NA? and other questions
- Is this normal?
- stock clutch problem?!
- Timeslips of 3.92's
- Shipping questions for a 3.2 pumpkin
- The Z is shuting off for no reason, HELP!
- anyone know the readings of stock coolant gauge?
- flywheel clutch
