View Full Version : Engine & Drivetrain
  1. Newb Question-- Whats difference between long block and short block??
  2. R34 transmission on 350z?? is that possible??
  3. engine block question
  4. '06 exhaust compatibility question
  5. good mechanic in san diego area?
  6. Exedy clutch and flywheel
  7. unichip or techno square
  8. Motul Eco-nergy 5w30 engine oil and oil consumption?
  9. Clutch and flywheel?
  10. Installing Stillen engine damper
  11. Z Emblem for Engine Cover?
  12. Level 10 recommendation?
  13. Tranny TSB
  14. ECU Reflash at AAM
  15. Fuel odor?
  16. Cams for '05 Rev-up Motor?
  17. Z on Website
  18. UTEC on completely stock Z?
  19. How much would you pay?
  20. Does the AC system use coolant in any way?
  21. Help - Looking to swap out pumpkin
  22. New NISMO exhaust MPG??
  23. solid motor mounts
  24. ?How do I know if my 5at has VLSD
  25. miss firing system?
  26. Az350z Pully set
  27. Power-shifting
  28. Cosworth heads
  29. Exedy Stage 1 Clutch Kit.....or......?
  30. Clutch!!
  31. Reflash at AAM this weekend... Need advice
  32. Signs that transmission needs to be replaced?
  33. Less total weight is worse
  34. normal oil temps during rush hour?
  35. 06 Z transmission Problem???
  36. Emissions Concern
  37. ebay engine torque damper
  38. Quaife ATB Helical Differential
  39. Jackstand points
  40. i would like a mild engine build in what direction do i go
  41. Question about installing 3.5 fd gear package on my 5AT
  42. engine / machine shop in upstate ny (rochester prefered)
  43. UTEC or Greddy E-manage Ultimate
  44. Little disappointed.....(dyno results)
  45. 350z swap engine???
  46. Is it really worth it??
  47. My tranny is acting Weird
  48. aem uego HELP
  49. newbie question
  50. Any NEW Mods out?
  51. engine breaking up at 2,500 RPM
  52. aem uego help??????
  53. Cams first or UTEC?
  54. WTB: JWT Clutch and Flywheel.....
  55. Engine Model and Serial Numbers? Where are they?
  56. ?? Valve body's effect on driving characteristics??
  57. 5/16" Installed and hood doesn't fit
  58. Kjr pulley is wiggling now... and a little bit of oil is coming out the hole
  59. AT Upgrade?
  60. Scott Performance custom grind cams or Nismo Cams. please help CANT DECIDE!!!!
  61. Diff whine when coasting
  62. CAM replacement saved my engine
  63. looking for Japanese parts for your Japanese car
  64. NISMO good or bad?
  65. Has anyone really pulled 300rwhp yet on a N/A VQ?
  66. Does anyone in florida know where i can get something like this done
  67. What does MAF stand for..and I searched...
  68. THX Custom CNC Stainless Steel Shift knobs
  69. Is there a magnetic oil drain plug made for the Z?
  70. Is there a NISMO oil filter?
  71. JWT clutch/fly done...
  72. Does anyone have any Dyno Results from ECU Resets?
  73. Anyone have any experience with this GroundingGear kit?
  74. Speed Limit
  75. Any improvement on the 5AT tranny
  76. Soot
  77. Install of UR Crank pulley and MD 5/16 plenum spacer
  78. MINE's GTR vs 350Z
  79. ur crank pulley Hp
  80. stock flywheel with JWT clutch?
  81. 3.9 Fd
  82. CEL question
  83. engine rattles at 3000rpm?
  84. dyno day
  85. Oil pressure after cooler install
  86. Unichip install and tune in Texas??
  87. Went to the dyno today!
  88. 3.9 FD Gears???
  89. Ecu?/ecm?
  90. ok now, need help asap...
  91. Ok im stuck with a dilemma help plz!!!
  92. 3.9FD Install SHOP?
  93. Are the axles considered powertrian
  94. Tranny Build Up? Tranny failed at the track.
  95. engine drop
  96. clicking noise (NOT AXLE) and tranny problem
  97. HOW TO: Calculate Difference in speed w/ different gearing
  98. Nismo cams
  99. Hooking up gauges question
  100. Dyno pre and post Utec
