View Full Version : Engine & Drivetrain
  1. Wierd clicking sound
  2. dynojet numbers
  3. Oil Consumption test...explain
  4. AAM reflash update!
  5. hmm clutch
  6. ATS carbon LSD @ Laguna Seca impression.
  7. Feeler: Brand New Nismo Cams
  8. Another what part should I get thread.....
  9. 3.9 FD or Clutch/Flywheel for Auto-X/Road Racing???
  10. Purposely skipping gears
  11. Tranny/clutch problem?
  12. High carbon in oil?
  13. Questions about the TS reflash
  14. What Do I Do Now?
  15. Unichip
  16. Tranny Trouble - Spare me Nissan!
  17. Koyo Radiator porblems?
  18. No oil? where did it go?
  19. UrbanImport??
  20. what are these... cams..
  21. Reflash or Unichip , Piggyback
  22. short shifter....
  23. Spark Plugs and Wires???
  24. Lucas engine oil stabalizer?
  25. Latest Crawford dynos . . .
  26. Set The Record Straight...LONG...SGP Racing
  27. Some questions about the eManage Ultimate
  28. Advise needed / New CM clutch against flywheel with only 1k miles on it, replace fly?
  29. Dyno results from tuning with Technosquare and Motordyne!
  30. Got $1500 bucks, How should I spend it??
  31. OEM 2005 Clutch Pedal Assembly on 03/04
  32. what tranny fluid?
  33. 2006 Grand Touring
  34. Nismo S-Tune Spec 2 Engine kit
  35. NA DYNO from my Z
  36. Question about building the motor.....
  37. question about 350z engine
  38. EU or UTEC in a 5AT?
  39. clutchmasters fx400 6 puck good for everyday???
  40. best motor oil for 350z that won't break budget?
  41. Christmas in January!!!!
  42. WHAT? no fuel filter!
  43. Thanks Bergenfield Nissan!!
  44. Quaife at last, Quaife at last!
  45. CLutchmasters fx200 good enough???
  46. ACT CLUTCH and Pressure plate
  47. AAM Hiring! Sales / Marketing
  48. Does anyone make a driveshaft loop for the Z?
  49. PLEASE need help to go faster!
  50. Turbonator lol!
  51. ECU tuning: flash or piggyback?
  52. Cost of Installing 3.9 Final Drives
  53. Best Clutch setup for Z?
  54. Anyone have problems power shifting with B&M?
  55. Crap for luck, help.
  56. Who said it can't be done?
  57. when installing my new flywheel....
  58. 350evo 3.9FD install questions
  59. UR Crank Pulley Squeaks...help!
  60. Wierd sound and a couple "hiccups" while downshifting
  61. Trans. Fluid
  62. Where to start?!?
  63. New Owner, Lots Of Questions!!!
  64. Best way to clean injectors?
  65. Questions for AT owners or someone who knows about AT trannies and tranny coolers
  66. Turbonator
  67. pullies
  68. pullies
  69. Problem with KJR crank pulley. Please help!
  70. New Z owner, Need ideas for some power ...
  71. Help!!! Dazed N' Confused!!!
  72. Got my car back from 7500 mile maintenance
  73. Return kit or larger injectors
  74. P/N for 05 ECU harness connector?
  75. Engine Damper and Crawford Strut Bar....
  76. Short shift
  77. Another 5AT shop
  78. How does a new tranny feel to drive?
  79. do I need a new pressure plate?
  80. "electronic fuel injector service"???
  81. the car revs on its own..
  82. How hard is it to tap an oil pan spacer?
  83. Help over here please!!
  84. Vacuum Manifold Manufacturers
  85. New dyno numbers for REV-UP motor
  86. Dyno Result Of Most Common Bolt-ons!!!
  87. Which clutch for stock flywheel? ACT/Clutchmasters/???
  88. Mods - can we get a sub-forum for drivetrain/tranny please?
  89. Short Shifter
  90. Acceleration Issues, help please!
  91. are companys even making aftermarket NA mods anymore
  92. 3.9 final gear noise?
  93. Quaife Nightmare
  94. Aftermarket radiator?
  95. Spark Plugs - Colder Plugs - Heat Ranges
  96. 75w90 or 80w90 for differential?
  97. Installing wideband NA
  98. Any break-in for the 350evo 3.9FD?
  99. best light weight flywheel regardless of price?
  100. Need pic/serial id for JWT and Exedy clutch disc.
