- my oil pressure stays at 120 psi!!! what is the problem??
- Stalling at 100+mph?!?!?!?
- GReddy oil pan vs OEM
- Baseline Dyno 06 Z!
- Next Mod???
- Unorthodox Ultra S Crank Pulley
- If you missed out on the THX SS CNC Shift knobs last time...
- Chip?
- how to deduce the version of transmission?
- Really Weird Transmission Problem
- OMG this sound is annoying!!!!!!
- Why no chatter about the Quaife lately? Here's some...
- BIG Power lost after mod
- no power when i gunning it. HELP
- tranny vibration
- fuel line pressure release
- Silly Question
- Clutch Question
- Whos got the swaps????
- lookin at a new clutch!?!?!?!?
- Nismo Cams - costs, worth it?
- Anybody who had a new transmission replacement (question) *?*
- Headed To The Dyno
- Thumbs up for 350evo shifter!
- what brand light weight bettery
- Has anyone had problems with their belts?
- Silvia/Skyline Final drive gear in Z?
- For those who had oil consumption issues, did it get better later on?
- Help.. what is the best Kind of belt? UR pulley
- my first dyno results
- Question about plugs...probably a stupid one but...
- Water in the engine?!?!?!?!?!?!
- jwt clutch an flywheel package
- Carbon Fiber Radiator Cooling Plate. Cool Mod!
- Oil pressure... less than 30psi @ idle when hot?
- Anyone in NorCal want to do a pumpkin swap?
- cams and reliablitliy?
- Strange noise from engine - detonation?
- Throwout Bearing Noise Disappeared!?!?!?!?
- check engine light
- 3.9 FD in a automatic
- What do I need to know before fixing NISMO cams?
- Nismo Grounding Wires...Genuine?
- Unorthodox Pulley Install
- please help
- Rear End
- Ugh... I'm on my 3rd Tranny... This is ridiculous!
- Too Much Oil Pressure?
- Is this normal? Need advice
- CMods Brake Torque Kit (Illuminated & Non-Illuminated)
- how do u know when u need a new tranny?
- VQ in a 300z?
- Has anyone bought from importboostwholesale.com?
- GB: AAM Billet Oil Pan Spacer and Line Kits
- Attn. Nissan Parts Dealers: '05 Service Manual
- Oil Catch Can Users (or experts alike)
- Curious about this pulley set
- lsd for a base
- SES Light is on in 03
- About how long labor wise should it take to replace...
- I wish I had the knowledge to put these on my car =(
- KJR Pulley sale
- New tranny... question inside!
- Matching Transmission Part # to the year it was made *?*
- Reseting the ECU...
- Got My Car Finally Dyno'ed!
- just bought my 06 new 350z
- Clutch and Flywheel Question
- Switching from auto transmission to manual
- A/T and shifting
- a little help?
- LSD issues or am i just retarded?
- Need Advice ( Service Advisor / Tranny Problem) !!!
- Crazy JDM Peeps! Nos'd / SC'd out Fairlady...
- OK who is the guru of sensor values?
- Help!!!!! Sparks at the right bottom area of the car
- differential leak
- Why is the Nismo clutch sold as 2 seperate pieces?
- Best Year Enthusiast to get for Mods?
- How much is a fuel pump assembly ?
- Possible tranny alternative for future
- 3.9 FD or Flywheel + clutch combo
- Vote on next mod!
- Any Internal Changes on NA Cars??
- Pulley install question
- Advice on KJR pulley damage...need your input!!
- ECU Reset
- Loss of power in second gear at low RPMS durring race?? NEED HELP!!
- what do you guys think of oil drain valves?
- Does anyone know the stock timing for the 350z
- Flywheel/Crank pulley ?
- New UR pulley now belt is squealing
- Neutral Safety Switch *?*
- LSD and fuel consumption ??
- Tilton RALLY in Georgia and Hawaii
- What is the stock timing
- JWT Clutch and Flywheel Installed
- Cams with rev-up motor
- What gauges do I need?
- Oil PSI Meter Fluctuating
