- clutch just started slipping, how long till it dies?
- Who is using the J&S safegaurd and is it worth it
- sleeved short block..
- Whistling transmission???
- Increased shifter vibration, sign of something else?
- After market tranny. Anybody using one?
- LSD for a base 350z
- modifications
- Top Speed Of Each Gear?
- Anyone have cam idle sound clips????
- Mobile 1 Extended Performance
- Research & development MSD coil's
- 3.9 FD with stock LSD or Upgrade to Nismo???
- Blown transmission yesterday (4th gear stuck)!
- clutch/flywheel
- ECU Flashes?
- Free Copper Iso Thermal MREV for 1/4 mile times.
- What At tranny oil cooler to get
- Plenum polishing questions
- mr. pulley vs. UR pulley????
- Stock Injectors
- Downshift Rev-Match in an 04??
- UR Pulley and Audio Systems
- Fluids?
- Blitz LM Racing Aluminum 2-Row Radiator 350Z
- computer programmer or chip?
- grinding
- VQ38/VQ40 strokers...
- Koyo Radiator (Issues)
- UR crank pulley impression
- Just an idea?!?!?
- Resetting the ECU??
- 6MT Transmission Fluid: GL-4 or GL-5
- nismo pulleys
- RPS Clutch and Flywheel installed...
- How much does backpressure cost?
- Taking Battery out for storage
- Engine Torque Damper - need a volunteer in Denver, CO region.
- 2004 350z Base Transmission Program Problem ?
- my baseline dyno before TT (rev-up)
- Racelogic Traction Control
- Stillen Radiator
- flywheels
- Crank Pulley and Lightweight pullies not making a difference in performance?
- For Those With A 3.91 Ring and Pinion Setup
- If you was in my position what would be your next mod *?*
- gearing options?
- Question on First Mod
- anyone have this combination?
- KJR Performance Pulley
- SPEC Clutch and Flywheel !! ANother alternative!
- question about a problem with my 5AT
- help with parts
- Cams and Smog
- Rev up head on no-rev up block
- What are your opinions on a Nismo LSD?
- Short shifter (and yes ive read a lot of searches)
- Who is using the J&S safeguard and your expeirence
- Camshaft Position Sensor A
- Whats the recomended brands for an intake and a short throw?
- Anyone use other diff oil for the kaaz diffs?
- crank pulley vs. whole set?
- Not Legal in CA?
- TOP SECRET parts?
- PC interface and software
- VENDORS!!! Apex'i U.F.O. oil filter?
- Engine specs for the VQ35DE
- Unorthodox Racing Pulleys
- Tunners in the Midwest?
- Had my tranny replaced in my 05, just one question...
- Differential swap for Z33 ?
- What fuse do you remove to burn out?
- Problem with cooling system
- Used Engines
- Weird noise from lightweight pullies
- Quaife Diff, If you have a fitment kit, I need your help!
- JDM got R205 differential ?
- What Oil Do You Use?
- Top Secret Oil Pan
- what the different between 04 05
- Engine dampener on Ebay?
- High clutch engagement point, and getting worse
- Grounding Kit..................Whatever
- Flywheel Alignment
- Emergency! Help!
- Oil consumption during break in period
- lsd on g35?
- lsd conversion help???????????????
- Koyo Radiator Install Question
- clutch question
- Dry Carbon front Strut bar
- 03 track vs 05 track
- 5AT with TN ST
- Grinding second gear.
- clutch / flywheel upgrade cost?
- Bpu?
- More Power
- What is the purpose of a Grounding Kit?
- ***electric Supercharger?***
- idle question
