- help! "KJR" light weight pulley...install... cant get stock one off??
- Car dying question....
- Ultrafilter oil filter= 5-6hp???????
- things that have made my tilton street clutch MUCH easier to drive
- The Z got G_tech'ed
- Clutch problem
- Clattering in engine
- Ok, I need your help guys.
- Here's my dilema... new stock clutch.... or fidanza flywheel?
- Reflash ECU
- flywheel question
- 350z ecu pin config...
- New Tranny going in..Is $1425 to much for Fly..
- G-Tech 0-60 runs in my auto Z
- Why is this happening?
- What it took me to get mid 13s in the 1/4 mile....(N/A)
- R/S Ratio for the VQ35
- 350EVO Race Shifter Install ?'s
- TCS and detonation
- Suprise found in Engine
- 3.9 Final Drive - DIY Help
- Has anyone installed an APS Strut brace?
- should i go from automatic to mannual
- What tranny fluid and clutch fluid to use?
- ATS Single Carbon Clutch
- AAM Dyno Day Cruise Video
- NGK platinum VS iridium
- Performance speed chip on ebay?
- Tranny being replaced, should I get the Nismo Flywheel?
- ECU Reflash for 2005s? AA or TS?
- convert 287hp to 300hp?
- Esprit Z33 Power Intake Kit
- Heater blows cool air!! HEELP!
- TechnoSquare ECU Reflash
- When is the right time to get a reflash?
- Fidanza Shifter Review
- Kaaz
- Q on Flywheel Clutch install
- Vq35?
- Top speed for each gear (6mt)
- $10,000 to $12,000...what do you do?
- High Idle + SES light....help???
- Want to get 287HP up to 300HP w/ no loss TQ
- ? for anybody that's looked inside their plenum
- question about a pulley set
- N20 or Supercharged? Which in general is safer in the long run?
- Disappointing Dyno #'s
- Almost have the Quaife LSD install finished
- WTF I thought is was a bearing!
- need advice on best lsd oil and friction modifier
- First Dyno
- Reset ECU and Homelink memory
- 380 hp without FI
- new engine bay pics
- Stillen Torque Damper.
- Ground kit contact points w/ Kinetix plenum?
- apexi super ground system
- ECU 6MT vs 5AT
- ECU relash: TS says 350zs run rich, AAM says lean! which is it
- if you were me. . .
- mods installed, feels like less power
- Redline water wetter question
- 1/2 the Weight or 2x the Power??
- 05 "High Rev" Motors.. +18wHP +22/29wTQ!? - A Thanks To Tony, Motordyne Engineering
- Latest Dyno Results - 283hp / 267 trq
- Just dropped off the Z at SGP Racing
- Vibration at high rpms
- 3.91 final drive questions
- Best Tuning Shop in Northeast Area?
- Lightened Flywheel
- Low RPM Help!!!
- ECU restriction mode?
- how hard is it to get to the spark plugs
- C-Foam
- Nismo Clutch and flywheel
- Another Next Mod Question
- SES code reader and reset tools
- idle raised after spark plugs
- SES Light & code 1283
- Whats a good spark plug set up for N/A
- Drivetrain Loss
- Oil Pressure at idle?
- If you were to start all over from scratch on ur 350z....
- 3.917 Final gear question...
- Shifter
- Here is my Dilema??
- Which rods and pistons for N/A engine?
- 350Z Chip Module Mod *need opinion*
- Stillen Valve Body Upgrade??
- sluggish labored performance on my z...help
- 350z performance enhancent
- Nismo Cams
- Nismo LSD
- Questions about Nismo Fuel Pressure Regulator (NA Use)
- Axle Question
- 300hp or 287hp
- Question on a smell from engine
- Gear ratio calculator
- Dont laugh serious question about G- Tech controller
- Skyline Engine in a 350Z?
