- noob question
- Is the ECU re-flash on par w/ a custom A/F unit with tuning?
- Chain Grinding Noises
- zeitronix
- Installing 6MT Tranny void my warranty?!
- crank pullies
- Why not underdrive?
- Adding gauges
- Checking Oil with Crawford Strutbar
- 1st Post: Hi Brothers and Sisters
- Who swapped their own differential?
- Nismo LSD Adjustments
- Question about 350z and G35 Axles.. sumone please help!!
- who's logged , looked at stock fuel trims
- Easy way through the drivers side Firewall?
- The million dollar question.....
- Service Engine Soon light...
- Nismo fuel pressure reg.
- Best way to determine if alternator is bad
- 3.9 vs 3.5 gear chart...link to old thread
- Who has the most miles on their Z??
- Optima Battery
- Outstanding Vendor!
- weird noise
- JUN Flywheel and CMIII Clutch are in! Kudos to CPRacing for a job well done!
- Crank Pulley Suppliers
- More stuff for my car.
- Reflash on the 300hp motor
- Grounding Kit??
- ecu reflash ??
- Oil Catch Can installation...
- Where Do I begin!
- B&M Shifter Install Question
- shift light
- 6MT final drive swap (again)
- CNR Crank Pulley ?
- Tonight i get a SES light?
- Differential
- Check this out, anybody have one?
- ECU reflash with cam upgrade
- Anyone NOT happy with 3.9 final drive on a N/A car?
- UR Crank pulley...Fuk it...
- Chip upgrade with Cams?
- Increase Power With...Sound Waves???
- KJR Performance
- 2003 vs 2005
- Power for New Z owner
- VQ30DETT swap?
- Will the V8 motor from the FX45 fit in the Z?
- Stillen Engine Damper install right?
- The Equalizer=1.6l 240hp...
- Differential Oil Catch Can
- Major front end damage selling all aftermarket parts
- GOT THE NEW TRANNY TODAY... SOME Qs
- Reflash????????
- SES light with new spark plugs
- 3.9 final vs. stock?
- Rogue shifter install Reviews (PICS)
- performance chips
- My baseline dyno results
- ATS LSD: Track Review
- Is Oil Catch Can Worth it for N/A?
- Oil Cooler vs. Oil Pan Spacer vs. Nothing?
- APS TT kit with Greddy Ultimate computer...
- Clutch Sticking???
- White Pride World Wide!!!!
- who would win? & what would it take?
- G35 VLSD On Z
- Cusco LSD Type RS 1.5 350Z Installed! And thanks to Sharif@Forged!
- RaceLogic After Market TC.
- knife edging the crank
- 350evo 3.9 gear swap....one word...WOW!
- Greddy Turbo
- TQ converter for a TT 5AT
- Spark PLug Recommendations
- Dyno pulls - which gear?
- Dyno anyone?
- Gas pedal
- Grounding Kit
- Vortech Tune (Dyno Graph)
- Fuel System upgrade
- Pi-Thon Locks and Samco Hoses
- Infamous Trans Issue
- A/f Ratio guages and sensors
- air/fuel gauge signal wire?
- Need member opinions on this?
- NA Spark Plugs
- Diff. Fluid, What's Everyone Using?
- clutch suggestions for potential FI use
- new pics: samco hoses and pithon fittings
- Weapon*R Engine Damper Test Fit.
- alphawerks or strup
- Any mods increase gas mileage?
- jwt clutch+nismo flywheel
- how many hours does it take to change valvesprings?
- G-Box Vendor?
- build my auto, or swap it for a heavy duty manual
- stillen supercharger and final drive
- who here has beat the piss out of their car at 7100rpms all the time with ECU flash
- please help me. Need help painting some engine parts
