View Full Version : Engine & Drivetrain
  1. name your 1/4 run and mods you have
  2. 2005 Service Manual
  3. Question about these ground wires--->
  4. Quaife LSD ... finally available!
  5. Looking for an installer for my 3.9 gear
  6. Attn: Performance Nissan Re: 3.9 Final Drive
  7. Vortech install help
  8. Twin Turbo Vs. Motor Swap?
  9. Rogue Shifter....nice!!
  10. Best NA Sound/Grind friendly Clutch+Flywheel
  11. Help- Do I have a fried clutch?
  12. Unorthodox Crank Pulley cause of A/C failure?
  13. buildup 300hp track engine instead of normal engine with standalone?
  14. New 350z
  15. Engine should be cooler now with this mod...
  16. SoCal shop to install 3.9 FD, clutch/flywheel.
  17. Revs bouncing at idle.... What does this mean???
  18. Tuning Question
  19. ATS Carbon LSD/Drive Shaft Shop Axles: Finally, a detailed review!
  20. Anyone want to swap final drives?
  21. nx maximizer with innovate wideband?
  22. tilton clutch and nismo LSD drive WAY better after wider tires/wheels
  23. Varis Air Duct
  24. Shifting ???
  25. delete this double post
  26. Innovate WB gauge install and Defi BF amber gauges!!
  27. No EGR system in the Z?
  28. Need Cam Help!
  29. I need help with the samco hoses
  30. Central 20 final drive
  31. grounding kit
  32. nitros...? newbie.. help please..
  33. Why Is My Car So Slow?????
  34. Oil cooler? Adv./Disadv.?
  35. REGRET- What mods have you regreted/ changed and why?
  36. Welcome your newest Z owner! :-)
  37. What should I do next..
  38. oil catch tanks
  39. anyone ever see a LSx powered 350z
  40. HELP !!! Can't get the crank pulley off on AT
  41. KJR Performance pulley/Street Image/ BRIDGESTONE
  42. Thinking of a fully built motor w/o FI
  43. What Will 3.5 gears Do To My Top End??
  44. OEM clutches suck...any ideas?
  45. What do i have to do to keep up with an STi!!
  46. I have OCD...guages for NA?
  47. Our 2nd Gear in a 6MT
  48. Digital gauges and sensors
  49. Does not going to dealer for maintenance effect warranty?
  50. Would pulleys finish of my warrenty?
  51. 5AT's
  52. Forged Internals Club
  53. Valve kit in use or photos
  54. Has anyone teamed a 350evo 3.9 final drive with a supercharger?
  55. What costs are involved in constructing a "built motor" suitable for FI?
  56. oem long oil filter vs. oem short oil filter?
  57. Mods
  58. ECU Reflash. Do I need custom programming?
  59. Looking for suggestions...
  60. NISMO vs. JTW clutch/flywheel ?
  61. Torque Converter Costs
  62. Synthetic oil
  63. Part number for belts?
  64. Engine dynos and dynojets...
  65. Magic Pellets Dropped Into Tank Give HUGE Gas Savings!
  66. JWT Clutch/Flywheel Break In
  67. Induction Lock Rings
  68. Anyone keep a fire extinguisher in the car?
  69. wtb: vq35 cams
  70. newbie and mods again im sure
  71. My Build List......need opinions
  72. Help me decide!
  73. Top Secret G35 V8 Twin turbo
  74. Looking for a good grounding kit, do I need a stabalizer with it?
  75. Dealer says "No" to nismo flywheel/clutch !?!
  76. Warranty: Mods Null and Void?
  77. SR350Z pictures!!!!
  78. What else can I do NA??
  79. has anyboady ordered from modacar?
  80. My car feels slower???
  81. Cheapest way to low 13s
  82. What is top speed in each gear?
  83. nextgear gaskets
  84. another motordyne spacer GB
  85. 03 ECU on 05 Car?
  86. GT300 350z VQ35 Engine Photos
  87. After using Synthetic Oil...
  88. new to Z's - how responsive are they?
  89. question about A/F's
  90. Dynoed Car This Weekend
  91. Rebuilt head and AEBS 4.3 Stroker Kit
  92. 2nd mod..I can't make up my mind??
  93. Thomas Racing microship???
  94. eBay short shifters?
  95. Install Shops Needed?
  96. Removing the fuse for the VDC/Traction control safe?
  97. ECU question?
  98. my review on the innovate wideband
  99. automatic transmission coolers: what do you guys think?
  100. Thinking ABout Becoming an AMSoil Dealer...
