- Thinking About Becoming an AMSoil Dealer...
- Oil CAtch can..where do the lines connect??
- Links to Dallas Area Shops
- Going from 3.3 to 3.9 gears on 5at...
- Estimate whp o hp
- Info: Nissan V8 450Z
- Transmission Fluild help please!
- Removing heads ???
- Taller Gears
- Naturally aspirated options.
- Ats Lsd
- What is underdriving
- About 1k to spend on parts...
- Changed AT5 pumpkin for a 6MT pumkin..got CEL
- Sr20det Into A 350z
- Where do I get this?
- Need help-clutch/flywheel or 3.9 final drive
- What's Up With AAM's Site?
- removing AC?
- 1st trip to the Dyno - tips please!
- i searched... where to mount wideband bung?
- N/A potentia?
- Just got some new Cams, Springs and Shims!!!
- High Clutch? want to lower your clutch engagement point?
- built motor
- Stroke changes?
- KJR Pulley Review
- SoCal Turbo install
- How safe/effective are octane boosters
- N/A Setup / What do you think? / Suggestions?
- Samco Radiator Hoses
- REVIEW!!! UR Flywheel + JWT Clutch
- World First MoTeC Plug & Play on 350Z...
- went to dyno...
- KJR pulley installed-first impressions
- Lsd
- Lightweight underdrive pulleys.....
- Motordyne 1/4" Spacer Question
- Front Cover Pics - after cam install
- SES caused by Tilton Flywheel
- Mustang vs. Dynojet
- Big traction problems!!!!
- Advancing the Timing, Yay or Nay?
- Any NA people with heads?
- Help!!! Engine SVC Light on!
- Can a Vq35 block be a Vq4460?
- Re-routing A/C lines
- Anyone blown their AT tranny yet?
- Got Aftermarket Clutch? Need Feedback PLEASE!!!
- Where can i find torque stall converters?
- Not doing mods till I learn to launch
- Loss of Power under 4K RPM
- First time on the Dyno. ????
- ATS Twin plate carbon clutch
- DIY on Radiator installation???
- Tensioner Pulley Torque Specs?
- Got my 35th Anniversary dynoed
- Break in period for performance clutch
- How is my A/F ratio?
- Infiniti to replace my CAS... CAS wire, too?
- blowoff valve w/vortech
- Paranoid about my AFR!
- Black Samco Hose Kit Worth Buying?
- Throttle Control Valve Bad/Ecu in Fail Safe
- UR Flywheel
- Anybody blow their motor N/A besides me???
- ex lurker! pics inside
- i want to rev to 8000rpm
- Who has a Z manual?
- How much beating can the VQ take??
- Anyone Using This?
- DLI twin spark igntion
- turbonator ??? WHAT IS IT??
- whats first
- How to remove radiator???
- Question: Do I need a short shifter?
- Feeler Turbonetics ST Kit?
- Computer chip reprogram or replace?
- Brake Fuse Mod Kits
- A question from italy..
- What do you think of this custom shift knob? Feeler?
- About to install UR Crank Pulley, reset ecu?
- My REview: Cusco RS Type LSD
- question about oil filters
- NA mods
- 6MT for 5AT Tranny Swap ??
- What ever happened to Crawford?
- airconditioner compressor and evaporator
- JWT clutch--how much power?
- funny video.
- DALLAS MEET & DYNO-DAY! Saturday 6/4/05
- New Dyno Results
- what kind of mods would i need
- Question About 05 350z ECU's
- Engine with More HP on our VQ35DE
- R.T.V.....how long
- CAMs without a reflash?
- Nismo Camshaft install and Idle Issues: Answered
- Help!! U/D Pulleys (harmonic balancer)
- Revised 350evo Short Throw Shifter (install/review)
