- Monitoring A/F and Timing, any tools?
- post removed
- IMR Grounding Kit
- AAM return fuel system gas vapour smell problem
- Prices on engine dampers - various
- JWT or Tilton clutch and flywheel
- ECU terminal numbers
- Dyno'd today on a mustang dyno - questions
- Anyone ever boiled their clutch fluid??? Help -- (long)
- Fidanza Shifter?
- Got my Z dynoed -- pleased with results
- Max Grounding System Review
- Engine Bay "Bling-Bling"
- Auto Tranny POwer Handling
- Quick question: How much coolant does the Z hold?
- Gauges
- 350Z/G35 turbo shootout headlines Sport Z Magazine Summer 2005 issue (cross post)
- 4k to spend
- Rev Limiter... where about does this get set?
- New Addition to the AAM Spec Horsepower Drive!!
- the gas tank?
- Does the 350z use a crank position sensor on the flywheel?
- What are Symptoms of Knocking?
- Changing Pulleyt
- DIY Koyo
- TC & VB Question
- Nismo Clutch + JWT flywheel
- Stillen Engine Damper Review
- Pulley Sets....
- JWT weight
- Best clutch to get with turbo?
- dyno #'s no ecu tuning basic bolt ons
- tilton.. in san francisco
- Clutch temporary sieze!!!!
- Greddy TT Engine Cover
- Getting Car dyno tuned tomrrow what to expect
- nismo ground kit
- Rant: I feel like a f*#king VQ35DE tester!
- Dynoed my NA Z over the weekend:
- ask for help
- $500 To Spend What Sould I Get???
- Does oil pressure drop after an install of a higher capicity oil pan?
- I broke my axle today
- Has your aluminum flywheel warped?
- flywheel Q
- Mas airflow problem? need help.
- I need a good shop in Southern California
- help
- is this true?
- twin turbo problem starting please help!
- Drive by wire
- Nismo thermostate/radiator cap
- traction control
- Tomei Releases a New Product for NA Fans!
- All motor Z.....
- motordyne spacer + HF Cat + Borla TD = LOUD
- replace 03 engine with 05 track engine?
- Wow
- Does a different final drive affect dyno numbers?
- Nismo engine tuning menu sale
- nismo 450hp VQ crate engine
- Cash burning hole in my pocket, what to do?
- rubbing issue?
- Switching the whole rear end.
- g35 coupe rear end same as 350z? (differential)
- Just changed clutch and stock was in good shape
- Where to start?
- joining the 600rwhp club
- Turbonetics kit installation in Central/South Florida?
- Quick question on 350Evo 3.9 pricing
- New Product
- reflashed ECU
- Part number for Greddy Oil Filter Block Adapter?
- ACT clutch/flywheel...Noisy!!
- Tranny cooler install question
- Where the anniversary power comes from???
- Horse power check, approximate hp from these mods...
- Carbon Fiber cold air Induction system. 10 HP Gain!
- Stillen Intercooler Install
- Tilton Flywheel and clutch
- New Tilton Updates....
- AAM Spacer VS. Motordyne Spacer
- OBD Code 304
- 4.5 liter swap
- Top speed...
- What shops install cams in L.A. (Cali) and how much do they charge??
- FS: 2004 g35/350z Mass Air Flow
- Need a straight answer about spark plugs.
- Guess what arrived today!
- JWT clutch/flywheel install
- What To Do???
- pumpkin installation
- ECU Reset recommended when modifying *?*
- JDM parts in the US??
- B&M short shifter anyone have one
- Lightweight Flywheel Q
- Ecu Basics
- How much serious interest is there in a complete ECU replacement?
- HELP..car just back from dealer/problems
- Turbo Timer Install Question. . .
