- Looking to build a spare pumpkin
- Rear diff.
- EVT sensor?? What is this?
- Another oil temp sensor question - Tap the sandwich plate or add another?
- which is trans fluid send and which is trans fluid return?
- Different between KACD05 & KACD04 plenum?
- Please give me the article number of CLOCK SPRING
- whats this on the transmission???
- 5AT to 6MT swap almost done...
- 4.08 and quaife in a base. Did I get something wrong?
- How to tell LSD rear diff?
- a 2006 clutch in a 2004
- Rear end ratings?
- JWT Clutch; OEM Flywheel?
- noob clutch & flywheel question. (:
- ARC V2 catch can hose sizes
- eml on since fitting Berks HFC s
- when the FSM says CAUTION, pay attention
- Clutch Issues
- HKS dli 2 questions
- Damage to Car Using Manual Mode?
- Cruise on a base with no aftermarket bs
- New clutch..stay with OEM?
- smelling clutch? or somthing else?
- i have no gears? wtf
- Emissions for LS swaps, need info please
- Pilot/Throwout Stopped Making Noise???
- VLSD?
- Clutchs?
- How to tell if I have a bad ECU?
- brake horse power & others
- Clutch/Flywheel install tomorrow.
- New Z Clutches
- Gears feeling blocked...
- jwt pop charger FILTER
- 2nd gear more jumpy
- Gear Calculator
- base 350z lsd help
- Clutch Help!
- Evap Canister years
- UR vs AMS pulley set
- Rev-up part number for exhaust cam plugs
- RB26DEbT 350Z build....
- Time Advance Concepts in Nissan Engine
- Oil Pan spacer problem install Problems?
- Can the valve covers be powder coated?
- Haven't worked on the Z in a while and looking to upgrd
- Short shifter cup install help
- OS GIKEN LSD question
- Engine Startup After 2 Months of Hibernation
- ~Finalizing Clutch Decision, Experience needed Please
- Customer's 350z LS3 Swap
- Premix for a Z?
- New Engine Harness Connectors...
- Should I Buy This Stock LSD?
- Auto with paddle shift 350z question
- cd009 revision list
- need help with a 3.69 gears question...
- Very Interesting Study on Gear Oils.
- Power wiring in the engine bay.. help?
- '06 engine in '03, '04 or '05
- Jwt vq35 adjustable exhaust cam gears.
- Clutch Fork Question
- Important Quaife QDF-11L information!
- 2008 vq hr manual transmission
- Need Help Identifying NISMO LSD
- Best DD clutch and flywheel
- Haltech not sending power to racepak
- Need help on a clutch and flywheel set up and question
- an idea of a build
- Cusco RS making a lot of noise when turning
- Clutch engage point?
- compressed air inside differential w/ quaife
- Twin Disc Clutch Help please!
- Review of RJM adjustable clutch pedal bracket
- Another differential question
- cv axle
- Project 600zilla - LS2+T56 350z swap
- Manual vs Auto Diff Side by Side Pictures
- Defi, Advance ZD Club Sport Package (RPM signal)
- Getting back into a VQ35......
- Cheapest Clutch Review
- Why hasn't anyone swapped to a FWD VQHR TB
- how do i know if i have the v2?
- aftermarket wideband gauge for use with oem wideband
- vq40 ecu same as vq35?
- 3.7 final drive gear for 350z hr 5AT(with stock LSD)???
- 3.7 final drive gear for 350Z HR 5AT(WITH STOCK LSD)
- In need of advice...
- cosworth oil pump ??
- VQ35DE Cylinder Block Numbers/Revisions
- Pi-thon Hose Locks/Engine dress up
- noob shifting
- How to tell what kind of tranny it is.
- 4.08 Question
- Whats that smell?....
- New clutch install - Now car slips and wont engage
- converting to a throttle by cable .. insight please
- Headers clearance
- Eneos Differential Oil
