View Full Version : Maintenance & Repair
  1. Im Just as Puzzled. Hopes this makes Sense
  2. Help! KEY FOB wont work after battery disconnect!
  3. Creaking/Clicking Noise Help
  4. Help!...engine studdering at WOT
  5. 04 g35 6spd transmission is failing
  6. driver seat problem plz help
  7. Lean with Bolt-Ons? Cause for concern?
  8. Is there a break-in period for new transmissions?
  9. Cam shaft position sensor problems!!
  10. Stock Z Alternator Output?
  11. Ligth heeelpp please!!!!!
  12. help with manual tranny fluid
  13. Mechanical Question - getting hosed?
  14. Rubbing sound from rear wheel
  15. Clutch noise video
  16. Coolant leak - investigation
  17. Z making whining sound
  18. VDC OFF/SLIP lights constantly on
  19. RPM jumping wildly
  20. Parking lights, tail lights is out
  21. 03 350z Engine knocking/ smoke from exhaust
  22. Nismo Cluster Install, TCS/Slip is ON, Related ? ? ?
  23. Help with hazards!! Fuse name?
  24. Speedometer is Substantially Off
  25. Front crash sensor
  26. Taillights out.
  27. Spark Plug Question
  28. wheel bearing sound or not?
  29. Vibration on right turns ~35mph
  30. oil in my spark plug well
  31. Gremlins in my Z (Momentum ST, CC STG4, etc)
  32. power window & power lock button unresponsive
  33. Strut Bar/Upper IC Pipe clearance issue
  34. Dumb question, but...
  35. Buzzing Noise! HELP
  36. Strange vibration once in a while
  37. noise from rear passenger side
  38. ODB II reader can't make connection - really weird???
  39. Starting issues
  40. Got P0462 code
  41. Clicking Noise
  42. New to the 350z
  43. Gas guage flactuations?
  44. Clutch Noise?
  45. something new every month
  46. Soot on rear bumper
  47. Keep blowing taillight fuse
  48. code p0442
  49. HOw to properly clean the TB and Mass Airflow Sensor
  50. Sudden power loss issue
  51. 5th Gear grinding with 23K miles on car!
  52. How to fix cloudy/scratched gauge cluster plastic
  53. $$for answer. Weird noise(drivers side wheel area)
  54. Flashing Airbag lights "HELP!"
  55. Check Engine Light
  56. Redline MT-85 Transmission Fluid Review
  57. HR A/T Transmissions Issues
  58. Manual trans rev help!
  59. Sesl: P0037
  60. Noise going into reverse
  61. Hit and Run
  62. Broken Windshield
  63. Locked up motor. Need your opinions. . .
  64. Window lock switch wiring.
  65. HELP!! Need some advice! Have a problem my Z..
  66. valve adjustment 2004 350z
  67. Problem with the oil pressure gauge! Plz help!
  68. Cruise control blinking
  69. VDC acting weird ?
  70. Loud screech sound
  71. Alternator and Constant Horn on when Locked..Any Ideas?
  72. Battery Charging Question
  73. Ses; vdc; slip
  74. help!! car stuck in limp mode tcs slip light on
  75. oil pressure not working
  76. Catalytic Converters bad from 2step?
  77. A Terrible Story(Help?)
  78. Car won't start!
  79. Help! Window stuck!
  80. Preventative maintenance and style: Silicone Hoses!
  81. Grinding Noise
  82. car's eating through oil.
  83. 3rd Fuse Box
  84. need to replace belt
  85. Question for rear diff fluid change...
  86. For people who have the Turbonetics Turbo Kit
  87. valve noise.. preparing for the worst
  88. Hit and run, now im screwed...
  89. Cooling issue on 03 Z
  90. p1126, p1122, no radio. No throttle response, only idle
  91. Service Engine Light ON
  92. tranny problem plz help
  93. need help driver window problem
  94. maintain 12v in system during battery replacement?
  95. strange cooling issue.
  96. engine harness
  97. Car jerks
  98. My Z won't start...need some advice.
  99. No go after plenum spacer and few other mods
  100. Did Nissan ever really fix the window motors?
