View Full Version : Maintenance & Repair
  1. Recharging the AC
  2. Question about Warranty?
  3. 2nd Gear Problems??
  4. gas gauge problem
  5. Buzzing sound at high rpm near redline.
  6. Acceleration lag when punched? clutch?
  7. Hydraulic Jack - Rebuild / Repair ?
  8. Alarm installed but now AC only blows Full and Hot
  9. Going to shops for maintenance
  10. I think I need a new starter...
  11. "Service Engine Soon" after installing new head unit.
  12. Anyone Knows
  13. Where to order stock sail panel where tweeter is mounted
  14. Horrible Idle Problem
  15. SES light /JWT Pop Charger
  16. Several issues
  17. Hit 85k miles.
  18. Heat from floor
  19. Headlight bulb replacement
  20. Transmission Or Clutch Problems?
  21. Loss of power and pulley belt noise...
  22. My 05 Z Starting problem
  23. Question about movement to the gauge needles
  24. Got a new Z and its got a code!
  25. shifter vibrates
  26. they werent lying when they said the Z was noisy
  27. Disturbing Find
  28. diagnostic code
  29. License Plate Light Help
  30. High Pitched Exhaust Note
  31. D: Tach Sticking in the 350z?
  32. Normal RPM when it's at idle
  33. Question about engine oil.
  34. Automatic Transmission Flush. PLEASE HELP!!
  35. Steering Wheel Column Noise
  36. Where is the water pump?
  37. Hi beam doesn't work anymore
  38. Advice for servicing
  39. Will G35 Rear Wheel Bearing Fit 350z? year 2003
  40. Look at my spark plugs..Should I be worried?
  41. Car running on only 5 cylinders
  42. oil change
  43. Do I need a tune up?
  44. **Oil Light Turns On When Making "Hard" Turn**
  45. 03 350z tire pressure sensor
  46. Maintenance
  47. Cat mount bolts
  48. 3 year mark - what to check/replace
  49. HELP... STOCK 350z has no power, vibrates, and the SES light is blinking
  50. Drivers side window automatically rolls back down...
  51. what the heck happened?
  52. Front brake squeaks
  53. knocking sound/stalling issue
  54. Warranty Question
  55. Back end feels loose
  56. Trunk problem
  57. coolant?
  58. Noise or Clicking?ticking sound
  59. Cleaning Belt and/or pulley
  60. Slip Light keeps coming on...Tire profile height?
  61. New OEM clutch, how many miles before I floor it?
  62. Weird issue (power windows)...
  63. Throttle Body Replacement
  64. What happened?!?!
  65. which is better for the car?
  66. Overheating problem after new radiator
  67. What is this part's name/number?
  68. Tranny drain bolt
  69. Door will not close/lock
  70. repairing small scratch
  71. Z is bogging any solution?
  72. ac intake?
  73. Taking car out of storage question "car wont start"
  74. Hole in CF hatch.. Can it be repaired/fixed?
  75. Noises gone!
  76. My Rear Wiper popped off when I shut my Hatch?!?
  77. Reverse wont werk
  78. 08 Nismo CEL light after/during going WOT
  79. Replacing stock air filter
  80. 350z Alignment Issue
  81. Removed Hatch Struts, now Hatch is misaligned.
  82. Car Squeaks WTF
  83. How much?
  84. Driver side valve cover gasket starting to leak? What to do?
  85. is it possible to fix a bent forged rim?
  86. Rust on hood
  87. Air leaking under the car towards the rear?
  88. Erratic Idle
  89. Removing the ac air vent cover
  90. Starting gear problem
  91. ABS pump
  92. Fluttering noise when i accelerate
  93. Weird smell started today while the heat was on...
  94. For anyone with the intermittent starting problem
  95. poping noise
  96. need help pls
  97. Anyone ever fix their BCM???
  98. warrenty help
  99. Rear Axle Clicking Service Bulletin
  100. Doors with window sound cheaply made!
