View Full Version : Maintenance & Repair
  1. Service Engine Light ON after Accident??
  2. body control module swap(have a short)
  3. Horn does not work!?
  4. coolant change
  5. Coolant question, please help.
  6. Tune up Time??
  7. P0300/ cold weather?
  8. Metal on Metal Scraping/Screeching noise from front of car
  9. P0340- Camshaft position sensor, hard starting and CEL
  10. 350Z Fuel Filter
  11. Headlight Fuse
  12. Help belts squeeling
  13. Stutters violently after a wash
  14. Clutch wont depress
  15. wierd noise during low rpm accel.
  16. Engine doesn't rev past 2500RPM
  17. Stock NAV stopped working "Disc Wrong Version"
  18. Wideband A/F sensor?
  19. VDC light and SLIP light
  20. Engine running rough in cold
  21. throttle wheel position...
  22. Other reasons for p2135 code than TPS?
  23. SES light: Cooling Temperature Below Regulating Thermostat Temperature
  24. Time to change out fuel pump assembly? HELP
  25. Under Shroud Hit
  26. Low oil pressure
  27. Help please !!
  28. Short interval winter garaging advice!
  29. need help asap with sound problem might be clutch unsure.
  30. Rear brakes don't fully disengage
  31. Weird Idle after car has been driven
  32. both windows do not fully close
  33. Anyway to adjust Clutch on Z?
  34. How often should I do Complete Fuel Injection Throttle Body Service?
  35. Xenon HID type/03 Touring
  36. HIGH pitched noise when starting
  37. Clicking noise coming from rear
  38. SES Light: P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring
  39. Turn signal issue?!!
  40. What is the capacity of Z transmission for oil?
  41. Cel 0132, 0152
  42. Best transmission oil for my Z?
  43. Easier way to tell the level of oil besides the oddly shaped dipstick...?
  44. vacuum noise in the rear tire area
  45. whistle type sound from exhaust?!
  46. 2003 coupe with 100k miles
  47. Strange Vibration Like / Humming Noise from the bottom of car???
  48. Left Window down overnight...it rained...HELP
  49. Shifting into gears...
  50. Question of Voltage @ Nats Ant.
  51. problem 350z
  52. missing then not whats up
  53. A/C and heater problems with overheating
  54. Z RPM's lag when giving gas...
  55. heater hit and miss
  56. Grip Pinch Weld Jack Adapter?
  57. I need help with my damn 350z....
  58. Reverse lights on all the time
  59. code problem or oil problem
  60. RPM Gauge is wrong near redline...Anyway to reset/relearn?
  61. Alignment Question
  62. just did my driving belts
  63. steering/brake issues?
  64. low idle oil pressure and engine smell burn???
  65. HELP! Winter storage potential problem
  66. 2003 Z wiper blade hose attachment
  67. VERY LOUD Whine when its cold
  68. Car won't let me fuel it to full?
  69. knocking noise
  70. 2003 Rear Main Seal
  71. service manual for 350z
  72. Something's wrong with my clutch.
  73. car wants to die after starting
  74. airbag flashing problem + horn not working... help!
  75. Need some help: Driver side airbag replcement
  76. Window Problems
  77. Car feels unstable while turning....
  78. need help with blower motor?
  79. Help, problem with my z
  80. Z starting up a little slow...
  81. Replacing throttle body ... what must the car reset/relearn?
  82. Pumping the gas
  83. Replaced Window Motor + still not working _SEARCHED_
  84. Help with rough engine Idle and Code P0174
  85. stealership question
  86. engine swap
  87. HELP! liquid wrench all over my car
  88. high milage maintence
  89. check engine light please help.
  90. AC Line Squeaking
  91. reverse light wont work
  92. thermostat/ engine coolant temp problem PLEASE HELP
  93. Possible alternative to avoid the "Coolant Purge Nightmare"?
  94. How to remove Secondary Piston from brake master cylinder?
  95. Problems with starting my Z
  96. Help with Seat Belt Tensioner replace.
  97. low oil pressure still
  98. Power steering problem!!
  99. Can't get rid of P0037 code
  100. cooling fans not running
