View Full Version : Maintenance & Repair
  1. Washer Pump Help!
  2. Nissan Dealer Service Question
  3. Instrument Panel Malfunction
  4. 350z heat coming in under gas pedal and passenger foot
  5. White Smoke, 10.0 a/f's,stalling, good headgasket....
  6. Spun out into a wall car was fixed, and now 3rd gear grinds everytime.
  7. right-side squeak... warranty over tomorrow, any suggestions?
  8. gas smell after i fill up
  9. Car shuts off, all electrics dead while putting air in tires
  10. Bizarre problem; Acceleration when cold
  11. Left rear brake light is out. Quick help needed.
  12. Front side marker bulb replacement
  13. Code P1103 MAP Sensor Heater
  14. engine overheat...
  15. Steering Wheel Wobble at 60mph and higher
  16. VQ35HR (P0345) Cam shaft Sensor Bank 2 Error
  17. Batterys dead, recommend a good charger?
  18. How to repair the trunk lock motor
  19. clicking
  20. whine noise when syncros try to catch up
  21. Where to buy Low Profile Hydraulic Jack
  22. hood is stuck, it wont open
  23. Help please
  24. Clutch pedal stuck
  25. Oil Consumption: Dealer trying scam ?
  26. Loud grinding sound from front of car?
  27. Clean inside of headlight?
  28. Clutch Pedal Return Issues
  29. Strange Noise Under Car
  30. Weird problem after starting???
  31. Air Conditioning / Climate Control White Box
  32. Z wont start intermittently
  33. Service Engine Soon? Everythings Normal?
  34. Worn Cloth Seat Bolster-Look Bad
  35. P0603 & P2135... Limp Mode.
  36. car will not start at all
  37. !! Trouble Locking Convertible !!
  38. No oil pressure !!!
  39. Rear hatch will not open, yes I did read the owners manual!
  40. rear clicking noise problem.. took to dealer and still doing it HELP!!!!
  41. I need help with this code P1051
  42. Universal Remote Programming
  43. 2003 350z base fuel gauge problem
  44. help with diagnosing tranny prob.
  45. Door Pannel Removal Help
  46. stange battery/altenator problem
  47. clutch issue..
  48. Convertible top woe. I wish I never bought a roadster.
  49. Need an 03 Fuse diagram ASAP
  50. New to the Z and already concerns plz help.
  51. driver side door will not open
  52. Loose feeling gas pedal. Anyway to increase pressure / improve response time?
  53. Kiwi in distress, No fuel. help!!!
  54. Cel + slip + vdc lights and no power and hard starting
  55. Clicking sound at low speed on and off accelerator?
  56. Tire Feathering On 03
  57. Will not start!
  58. Let's play a game. ID this interior plug.
  59. Window roll down.. strange
  60. check engine light and various codes
  61. Battery and Alternator? Why?
  62. What to do?
  63. Got a SES light...P0011
  64. Alarm Problems?
  65. Clutch won't disengage. 2003 g35 6mt
  66. Guage issue, Not reading correctly.
  67. Maintence for the Z with 35,000 miles
  68. Did I destroy my engine?
  69. Rear Squeaks When Going Over Bumps
  70. PLEASE HELP!!! Service Engine Soon, TCS OFF, SLIP Lights, Car won't go!
  71. Vibration in front passenger wheel
  72. How do I burp my cooling system?
  73. wierd sound?
  74. Water leak on the interior when raining
  75. ***Help. AC went out. Florida :(***
  76. Evaporative Emission Control Valve (P0455)
  77. Major Issue with 04 touring auto
  78. Replaced Window Motor - still not working
  79. Oil Change 5-30w or 10-30w?
  80. screwed transmission, loose exhaust?
  81. 3 pod oil gauge to high 2004 350z
  82. Fuel tank won't accept more!
  83. Help with Clutch Switch
  84. Fuel Problem...Need Help!!
  85. Almost dies after start up.
  86. A/C Sensor issue
  87. Occasional starting problem.
  88. Overheating while parked but once moving no issues. Please help
  89. Simple Noob question about car alarm.
  90. CA: No OBD2 Scanner for you!
  91. Pwr window demons on 04 roadster
  92. Cabin temp
  93. Alarm Problems.
  94. Hit and Run
  95. 04' 350z door lock??
  96. Chased "oil leak" to here, ruined my day!
  97. Window motor disgust
  98. Help removing crank pulley when engine is out of the car????
  99. multiple cylinder misfiring code popped up
  100. Poor Mileage Solutions Reasonable?
