- Radio/Audio system ON, while the car is totally OFF
- 5th gear grind, and warranty question
- starting problems, 6speed
- Remedy for Leather scratches
- Rear Axle Clicking Noise???
- Where should I buy a window motor?
- What oil make and filter make do you use?
- How to aim the 06 headlights?
- scratch on my new headlights
- What happened to my car?
- Brake light on and off
- abs,brake, vdc lights on
- 2003 350z 6 disc changer jammed?
- Door losing power
- Sluggish 07'
- O2 sensor help
- dashboard lights and guages dont work
- Mechanical Question?
- Problem after installing new battery...
- need help for something
- something weird happened today
- My a/c vent switch is wacky after engine repair :(
- yet another rattle thread
- Possible O2
- The tranny rattle again
- MOTIVE POWER BLEEDER DISCOUNT CODE - all motive products
- Broken windshield
- need wiring information for the ac pressure switch
- Whining (sounds like a s/c) in all gears at ~3000rpm+
- Loud shrieking noise after knock sensor replacement
- synchro cost?
- Axle Problem
- jackin up the car
- Check Engine Light after Grounding Kit installed
- Oil Change EVERY 1900 Miles!!!!!!!!
- HELP, check engine light
- Transmission fluid
- Slip light
- Changed my pads and rotors today and a few issues
- Car sat for 5 straight days now problems
- Keep performing Idle Reset Procedure - works fine until I restart my car.
- Bad Fuelpump?
- Help! SES light problem.
- clutch and flywheel
- o2 sensor help please look
- Click when driving off.
- Brake dust on Tenzo R Wheels
- The run around
- Clutch Problem
- Approaching 100k - questions: engine, clutch, plugs??
- A/C Blower
- eBay seller selling 350z taillight overlay kit with wrong item
- Removing a stripped nut: need help quick!
- jwt tt
- Rear wheel bearing
- P2a00
- help with ringing noise from clutch
- Motul Transmission Fluid
- Where to connect 134a refrigerant recharge kit? Need pic, please
- Help with stock head unit install!!!!!
- Engine dies after ECU reset
- car undercarriage
- Clutch Lever Problems
- rattle coming from rear right tire area when car starts driving from a stop
- Tappet nightmare
- Couldn't start the engine!! help
- TPS indicator warning light question
- what brand (or model ) of window motor do I get?
- high frequency sound when accelerating from 0 up
- Electrical Problem
- Need help asap!!! P2135 tp sensor light is on!!!
- Grind when shifting into 5th?
- Yaw Rate Sensor ?
- dead battery
- Mysterious front end knock. Help!
- hatch strut installation
- Electric Window not working on 07 Z
- Is there a way to disconnect power to passenger door?
- White smoke under WOT
- 03 5AT transmission problems?
- Idle drops way low after installing the Optima battery...???
- 3hree5neoero - window motor
- Grinding Gears!!
- Utec problem
- 2007 Manual Tranny sticks in neutral
- What part is this hanging under my Z?
- idle problems 2003 350Z
- Rear Bumper Paint issues
- Car Starts - No Throttle - Key Related?
- Passenger rear CLUNKING/RATTLING fixed!
- Gas Gauge
- car died while rolling 80 on freeway...help..
- my power seats going to die soon
- Need part Name or #
- Good ole' Tranny Questions
- Previous Lurker, now member has a question...
- Air bag help Please!!!
- Ideas on securing main wiring harness??
- got stranded on the side of the road (Diagnosing)
- Help me please engine wont start
