- back fire after new plugs
- Can anyone shed some light
- Anyone changed there own coolant, question
- Power seat issues
- matience
- Hks true dual exhaust maintence
- Clutch pedal will not return
- Scuffed Bumper - Can I fix it?
- Jack stand location
- Oil stain. Are they from brake or suspension?
- Whining Noise??
- Grinding Disc
- Thiefs= worthless. Theft caused interior probelms.
- Broken bleeder screw
- Hatch not closing - anyone else?
- Help dash stopped working??
- AEM Cold Air causing trouble (kinda limp mode)
- steering problem
- Front Bearing for G35 Coupe
- windshield wiper help
- check engine soon? code p1084
- Something is wrong with my A/C any suggsestions?
- engine swap price
- Another car won't start thread
- part# for replacement window streak felts?
- this felt out from the bottom of my car... any idea?
- No more honk when I lock the doors!
- Nismo Cold air ripped off by tire
- Limp mode!
- HELP Please! Weird Leaking place
- passenger side floor hot!
- Screeching Noise When Turning Hard Left and Braking
- Help plzz
- brembo caliper leaking need help!!!
- 2003 Touring Help! please
- Wierd problem...car turns over excessivelly before starting and has no power....
- A/C receiver/ drier
- High Oil Pressure on start
- what is happening to my wheel?
- Clutch Problems
- Noob needs electrical help
- Trans and Clutch Issues
- 350z Keeps Dying On Me :(
- berk high flow cat bunged up again!!
- Air Conditioner cut out
- Problem ??? Intermitent Starting.
- Leak on passenger side, fender area
- High pitch noise coming from rear, vid attached.
- Clutch problems!
- changing transmission fluid
- not sure if its clutch or clutch pedal...
- Body Ground F152 ???
- Parking lights, interior lights, fan won't turn off
- Motor Dies After Start Up(unless rev'd)
- Cleaning Cold Air Filter
- Tune up?
- Power Steering?
- When taking the keys out windows roll down on their own.
- AC/CLIMATE CONTROL computer mount...
- Standard Maintenance at 12K Miles?
- P0183 and gas gauge wont work...
- Please help with this cooling system problem
- HELP! Trunk won't latch
- Noobie to the Z needs help.
- NEED HELP ASAP..slip light comin on intermentilly...
- HELP.. ABS/check engine light on
- 50 000 miles !
- Alignment question
- quick question
- can I use a stronger fuse?
- Air Conditioner Relay
- Turboed 350: Will Not Start When Hot?
- Small Jobs
- 2008 fsm
- Airbag off warning after set removal.
- oil pressure gauge and check engine light
- help with rounded nut
- Help!! Rev can't get higher than 1800rpm
- Krazy glue on spash guards
- Need help with moonroof Please
- Rear suspension, hub, wheel? Squeaking & Creeking over speed bumps/driveway
- Weird sound
- cigarrette lighters not working, please help!
- Trip computer showing RPM
- Oil Pressure......:(
- PCV Valve
- Royal Purple Question......
- Wow....had to have car towed to stealership....plz help
- Brakes
- How much are dealerships charging to fix a head gasket?
- APS Test Pipe mounting brackets
- Time for oil change?
- Smoke! Then nothing.....
- *sigh* Can't remove oil filter
- HELP!! Car shakes at 2000 RPM!! HELP
- tranny problems
- tire wear pulling car to right
- driver side vibration after alignment
- 2004 Touring power seat track issue
- Clutch problems - 08z
